Monitor Suddenly "No Signal"
On 1/5/2020 at 7:21 PM, redteam4ever said:So, what IS the system doing? Are the fans spinning? Is there any beeping? Can you hear any sounds confirming that the OS booted? (If you wait for a couple of minutes, you can press Shift five times to get a dialog for turning on Sticky keys - it makes a sound)
Fans run cpu cooler runs the system hardware except monitor and mouse, keyboard do not work. Replaced with another Asus Prime X470-Pro thought it was the problem however it is not. Never seen that happen before. It's doing the same thing as yesterday no signal on monitor and in active keyboard and mouse. Resetting CMOS did nothing either.
I know it's not the GPU cause works like normal with my old intel board everything works with the intel board.
EDIT: Solved. Dead stick of RAM.
