I wanna say no.
Your whole PC specs?
Which 400watts PSU?
Which 980 Ti?
Welcome to the forum!
Seeing as the 980 Ti uses around 250W on its own, not knowing your full system, a great quality 400W would not even be recommended, but would work.
A 400W PSU where you don't even have a 6 pin and have to use molex? That's a solid 'NO!!!' from me.
Get a new good quality 500W+ PSU.
Tier B+ or better.
Even if it was a really high quality unit, 400W probably wouldn't be enough for a full system with a 980Ti, but since you mentioned Molex to PCI-E adaptors, I'd assume it's a pretty cheap unit anyway.
So basically, you'll need to buy a new PSU. Go for at least something like a Corsair CX550M, if you don't want to spend a whole lot of money. For other options, check the forum's PSU tier list here.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
