BEST CPU for RTX 2060?
With this current setup, what cpu is best to handle RTX 2060?
Ryzen and Intel recommended pls.
Ryzen 5 2600 / MSI B350 Tomahawk / GALAX RTX 2060 6GB (1-Click OC) / Corsair Vengeance LPX 2666Mhz 8x2GB / ADATA SX6000 LITE 512 M.2 NVME / KLEVV 128 GB SATA / Seagate Barracuda 2TB 7200rpm / Seasonic Focus Gold 550W / Tecware Nexus C
Upgrade Plan: CPU: Ryzen 5 3600 RAM: GSkill TridentZ RGB 3200MHz/3600MHz MB: MSI B450 TOMAHAWK MAX
Ryzen 5 3600. i5 9400f if for some reason you want to pick something on the intel side (And believe me, you don't). Ryzen 5 2600 if you want something cheap that will last a few more years.
Btw, can I do little overclock with B-350 motherboard? The reason i ask this because at gaming, sometimes i had a 'fps drop'. Like -40fps -20fps -60fps. I see ryzen needs fast ram like 3200. Now, i have 2666mhz. Is it worth it to change?
You'll be fine with what you've got, don't worry. Get the 3600, don't overclock and just leave the ram as it is.
