I was helping to set up a present for someone and they're having quite a bit of difficulty because the 'livebox-tv' android tv box seems to have an interface that implies a touchscreen interface.
Is there a way to set up an android tv box to work without a touchscreen with a user-friendly interface? (think people in their 60s trying to use this thing)
edit: I should probably detail more carefully: the main issue is that loading android 'apps' have a scrollable interface, but there's no scroll wheel or touchscreen to scroll with.  Some seem to require you to tap the screen rather than arrow over with the 'remote', thus making it unintuitive.
Edited by 7he404guy
more details
If I have to explain every detail, I won't talk to you.  If you answer a question with what can be found through 10 seconds of googling, you've contributed nothing, as I assure you I've already considered it.
What a world we would be living in if I had to post several paragraphs every time I ask a question.
