Hi there,
I have a pc on which I used equalizer APO and Peace (peace is just a UI for APO) to bass boost the audio. That pc is hooked up directly to 2 proffesional grade amplifiers.
However, since it's bass boosted, the audio clips at (relatively) high sound levels. Is there any way to fix this? like getting a discrete sound card which handles this bass boost a bit better? (it's hooked up to the integrated sound card right now)
Or not bass boosting using software at all and getting a seperate equalizer?
Or is there just nothing I can do against this?
Thanks in advance :)
ps. I know I can just make the bass boost less agressive but I don't want less bass ?
https://linustechtips.com/topic/1133076-lessen-audio-cipping/
Step one seems to be if the clipping is actually an artifact of the bass boost function or not.
Does it clip when the bass isn’t boosted?
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117377
@Bombastinator No, it doesn't clip when the bass boost is turned off so that does seem to be the problem
@Nimrodor That's the problem, I don't want to do that because then my volume would be lower :p
Wouldn't a sound card work because it can output at a higher volume?
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117721
@Nimrodor That's the problem, I don't want to do that because then my volume would be lower ?
Depends on if the sheer volume of base is what is causing the clipping.  If it’s that loud you could be just overloading things.  Might not be something you can edit.
This is why people put absurdly huge amps in car audio.  Thumpa thumpa eats a lot of power.
IF this is the issue, a subwoofer with its own amp might help. Split the 2.0 into 2.1 and make the base its own thing.
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117767
that won't work, we allready have our complete audio set, we've just been using it by dialing back (lowering the volume) the amps a little
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117912
You need to do the opposite. Dial back the preamp on the PC so that the PC's output is clean, then increase volume on the amps to get what you need.
F@H
GPD Win 2
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117917
ok well that sounds sensible ?
(that I didn't think of that myself lol ?‍♂️)
but if I do this (so I have a clean output signal from my pc) will I be able to add a pre amp between the pc and the amp to make the signal a little louder?
I might just try that and return the pre amp if it doesn't work but if you guys know for sure that it doesn't work I don't have to try of course ?
EDIT: I think i've tried that before and the audio still clipped, however, i'm not sure, so I'll have to find out this friday I guess
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117936
If you've made sure the PC's output doesn't clip and there's still clipping then it's either the amp or speakers that can't take that much.
Possibly, unless the above.
F@H
GPD Win 2
https://linustechtips.com/topic/1133076-lessen-audio-cipping/#findComment-13117968
