Recently bought CoolerMaster 212 Turbo LED (needing some tech help)
Ah.  Because it’s rgb maybe?  I don’t know much about rgb, but I was told that rgb devices have two sets of plugs.  One for the fan and one for the lights.  I’m guessing that the 4 pin one is for the fans and the 3 pin one is for the lights.
The pin missing is in the middle, right? That's how PWM splitter works. The missing pin is for RPM and since motherboard can only read one signal for RPM per header, there's no need for that pin.
The rest, DC, ground and PWM are needed for both headers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
So it’s not rgb?  And it’s not split?
212 Turbo LED isn't RGB. It has red LEDs which are powered by same PWM cable with fans. The cable is normal Y-splitter for fans.
So normal y splitter for fans has 2 plugs on the tail of the Y. A 4 pin and a 4pin with one pin removed? Seems odd.  Is it each one is supposed to be one end of the Y and it just doesn’t have any actual arms?  That would make more sense.
Its called that because it has two headers on one end and one on the other. There are two kinds of Y-splitters. For DC fans and PWM. PWM have 4th pin for PWM, DC have just power and ground with rpm removed on the other header. The end going to mobo ofc has all pins.
I'm not quite sure if this is more of you trolling or actually lazy to google and see what kind of splitter Y is.
I’ve never trolled here.  Or anywhere else in years.  Trolling annoys me.  I try not to do things to other people I find annoying.  Believe it or don’t.  I’ve used dc fan splitters and they actually were Y shaped.  Well, more V shaped actually. This one seems to be I shaped.
