Could you elaborate a bit on what you want to exactly do?
You can make an in a cell in column B if-statement that does something when there is data in the cell in column A next to it. But if that is really what you want, depends on what you are going to do.
https://linustechtips.com/topic/1128728-excel-help/#findComment-13085299
Formulas that reference the cells as variables
But it really depends on what you want help with specifically
https://linustechtips.com/topic/1128728-excel-help/#findComment-13085306
Ended up helping OP in a private message. This was the formula needed at the end:
=IFERROR(IF(AND(SUMPRODUCT(--ISNUMBER(C11:G11)),NOT(SUMPRODUCT(--(C11:G11<>""))=0)),D11-C11-E11-F11-G11,""), "Data is not correct")
This checks if all the applicable cells can be counted up + have data in them.
If it gives an error, there's incorrect data. If it gives a number, that's a valid result. If it's blank, there is no data yet.
https://linustechtips.com/topic/1128728-excel-help/#findComment-13085631
