6 minutes ago, Ofterity said:
I would like to know if there is something I should get or change in this list?
Click here for the PC build
the motherboard is not that great, you're better off with a tomahawk max and add a separate wifi card.
how did you manage to find a $343 RX580? for that money you can get a rx 5700xt. or for less money you could get a rx580 rog strix for $170.
If this is a gaming only build, you can find a cheaper ssd, as you won't notice the difference.
also, you can get win 10 on ebay for $10
I'll output a full PCPartPicker list of what I'd change but my first impressions are:
-Motherboard is a bit spendy, for best VRM you're better off on Gigabyte or Asus at the $194 board level
-The SSD is quite spendy, if this is for gaming only on that storage you will see no benefit vs a regular NVMe drive that isn't PCIe 4.0.  I'd ask you to state what your exact uses are that you're trying to optimize this computer for.
-That GPU is WAAAYYY overpriced, you're paying for fluff and not more FPS.  For $343 USD you should at LEAST be getting an RX 5700 if not at least a 1660 Super, but not an old Polaris RX 580 that thing can be had for sooo much cheaper.
Just go with Slottr's build, yours has a lot of issues with, the R5 3600X is not needed as it is the same CPU as the R5 3600 in every way, the MSI MPG X570 GAMING EDGE WIFI ATX AM4 Motherboard is literally the WORST of all X570 motherboards and so on...
Personal Desktop":
Luna, the temporary Desktop:
3 hours ago, Ofterity said:
I am quite limited on PC parts as many here in Norway tend to be really exspensive or just not accessible in stores for some reason.
Umm if you needed it to be Norway, why did you leave that out at first and link to PCPartpicker for the USA?  There is a pcpartpicker for Norway yo:
https://no.pcpartpicker.com/user/Ofterity/saved/7mpXvK   (I just clicked the norway button on your parts list, doesn't look like some of the stuff you picked at first is available there anyway).
What's your budget in Kr  and what should we be building for?  1080p gaming?  144Hz 1440p gaming?  Do you need a new monitor (would be waste to run basic monitor on a GTX 2080 super).  Please provide more info to get build info useful for YOU.
Here's a rough-draft idea of a bang-for-buck gaming build converted to parts on PcPartPicker Norway:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (kr2254.00 @ CDON NO)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (kr1791.84 @ Newegg Norway)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  (kr849.00 @ CDON NO)
Storage: ADATA XPG SX6000 Pro 1 TB M.2-2280 NVME Solid State Drive  (kr1431.00 @ CDON NO)
Video Card: PowerColor Radeon RX 5700 8 GB RED DRAGON Video Card  (kr4399.00 @ CDON NO)
Case: Fractal Design Focus G ATX Mid Tower Case  (kr628.00 @ CDON NO)
Power Supply: Corsair RMx (2018) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (kr1299.00 @ CDON NO)
Operating System: Microsoft Windows 10 Home OEM 64-bit
Total: kr12651.84
Generated by PCPartPicker 2019-11-26 20:56 CET+0100
It oddly didn't want to price OS, but you can save some money and use a prior Win7/Win8 key with the ISO of Win10 from Microsoft, could go that route.
