I'm looking in to buying a used system with the following mobo:
https://www.gigabyte.com/us/Motherboard/GA-AB350M-HD3-rev-1x/support#support-cpu
It's comes with a Ryzen 5 1400 (which is 4c/8HT) and I'd like to bump up the CPU to something more in the vein of 8/16 (or so)
I am far more of an Intel Xeon fan, so I really don't know the "bang for the buck" on Ryzens here.
Looking to spend ~200$ (USA) for a new CPU for that 'board.
Suggestions based on what the board will support?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1123287-help-with-cpu-choice-based-on-link-inside/
Im assuming you will use the stock cooler?
For 200$ new:
2700
Microcenter may have some cheaper 1700 (or derivatives) or 2700 parts.
depending on where you are, microcenter is having a great a sale on a 2700x ($130). Even without that the 2700/2700x can be had for ~$200 on Amazon/eBay.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
@GoldenLag
@Mnky313
Apologies, yes, stock cooler, no OCing
Nowere near a microcenter, I'll have to buy online (newegg, amazon, etc)
$200 gets you a Ryzen 7 2700 at best, in terms of cores.
Primary PC:
PSU tier list
How many watts do I need?
yeah ill recommend 2700. the X version is not worth it.
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
SO I'm going to assume that's good value for money? This is not a gaming box.
Well, the pricing on last gen 8 cores has dropped a lot, the 2700X is $190 on Amazon, the 2700 is $170, and the 1700X is also $170. Of these I think the 2700 offers the best value, but the 2700X is still in your price range. What's the use case?
Primary PC:
PSU tier list
2 minutes ago, Radium_Angel said:
number crunching in excel and tax code work.
sounds like 8 cores is rather excessive, any cheap Ryzen 5 model will be more than enough for that task.
Primary PC:
PSU tier list
Probably, but I'm getting the whole system (with the older chip) for 150$ (16GB RAM, 512GB nVME, rx580 etc) so I figure I can splurge on a new CPU.
