15 minutes ago, StaySideWaysYT said:
i recently overclocked my corsair 16gb 2400MHz ram using xmp profile to 3000MHz. i watched a video and they didnt say to change the voltage should i leave it or bump up the voltage? also i tried to bump it up but it was grayed out so i couldn't change it.
1.2 volts is a very healthy voltage for DDR4. I'm unsure, but XMP profiles may control the voltage, potentially why you're not able to change it manually.
If it's stable, then it's clearly perfectly fine. If it's not stable, then find a way to increase the voltage a bit ?
Sig under construction.
1.35 volts is common for DDR4 so there's no problem with 1.2
Primary PC:
Usually 3200MHz can't do good timings with only 1.2V (Crucial does sell 3200MHz CL22 1.2V kits) say CAS 16, but if that's what you want it's totally fine. I myself will just raise voltage and see how far sticks will go
Desktop benching:
