Cleaning of insides of PC with a friggin 90 mph blower. What could go wrong?
10 hours ago, RAGNES7 said:my motherboard is a X470 Gigabyte AUG and maybe it is most that matters.
So, what im planning to do is, clean the PC case with a 80+ mile per hour blower. call it a mini leaf blower but, i wanna know is this a smart idea?
there are no debris. i clean my PC every 40-60 days or so. but i can clean GPU, CPU fans and fins and the front pane fans and the crevices. for that purpose i am planning to use a air blower to clean it properly.
Any tips and sugestions? im open to idea of "dont do it please" too
I'd recommend not doing it because two things will happen:
1) air pressure will "lift" things off the PCB's, the air pressure should be not enough to force your hand to movement if air is pushed at it.
Solve this by keeping some distance, or if you have some kind of diffuser in front (eg think hair dryer attachments that spread the air into multiple nozzles/line) that will make the air less concentrated.
2) It will move moving parts in the wrong direction and create currents back fed through the electronics.
Now this is a little easier to prevent damage. If you can remove the fans, remove the fans before using the air pressure on heat sinks. If you can not remove the fans (eg MB chips, GPU) then make sure the fan can not spin before using air pressure on it.
If the fans spin while air pressure is being applied, it will damage the fan, and likely the PCB where it's attached.
