11 minutes ago, masethekiller said:
Anyone have more info on this than press release. They don't even provide a release date but I presume around 1660 super. Hopefully this card is good/cheap or pushes down prices
We have 0 info, it's supposed to be like 25% faster than the RX 580
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12961038
Well. Igor's lab estimates the card to be on par with the 1660 super, that sits between the 1660 and 1660 TI.
While raw numbers (core/memory speed) indicate something like that, it doesn't make any sense to compare it to the 1650.
Amd talks about the 4gb version to beat the 1650 by 37% in select titles, but that would put it on ar with the 590 and 1660, not the super version.
Unless ofc 37% faster than trash sounds a lot better than on par with XY.
Currently the prices are the following in Hungary.
1650: 165$
1660: 235$
RX 570: 165$
RX 580: 200$
RX 590: 235$
(quoted prices are the cheapest that can be found, in case of amd, 8GB versions.)
I didn't really follow hardware news until recently, when i started building my new machine.
But i suspect the starting price will be around 200 or more, and the 580 and 590 will drop in price.
Because if this card would come for around 1650/RX570 price, nobody would buy the remaining supply of 580 and 590.
That is ofc if it delivers performance on par with those cards.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12961221
From what I can tell with the specs and pre-release info, it should have performance just under the 1660TI... It's also going to have 4GB and 8GB versions, but retains the GDDR6 memory. It will only have a 128-bit memory bus, limiting memory bandwidth to half that of other GDDR6 implementations, though it's still well above that of all all cards with lower performance than the 1660TI, as well as a higher memory clock than the 1660TI. It will only require a single 8-pin power connector, (150w maximum power draw) and it will be PCIe 4.0 compatible. (which only really matters if you're putting it in a PCIe 4.0 x4 slot, which should have the same performance as sticking it in a PCIe 3.0 x8 slot)
This is all absolute bare minimum spec, so expect performance to rival the 1660TI for most AIB boards, and/or for an XT version that can match or beat a 1660TI Super. (if Nvidia ever decides to do such a thing)
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12961246
23 minutes ago, masethekiller said:
What's an aib board? The card after the "reference" one?
AIB is the partner manufacturer's designed board versions. They are anything that isn't "reference", regardless of when they are released. (some cards don't have a reference model, and some release the reference model at the same time as the AIBs)
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12961314
That'd mean, the expectations of this being a 150$ card are a far cry from reality.
At the other hand, a 1660 super or ti is anything but a 37% improvement from a 1650.
Would they understimate the capabilities of the card so much?
This whole announcement was a mess, with so little information.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12961416
Yeah, this is looking to be a $200 card at the low-end.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12962939
14 hours ago, masethekiller said:
Hopefully you can bios hack the 5500 to 5500 xt like the 5700
And risk bricking it? I doubt there will even be a dual BIOS version.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-12964238
  • 1 month later...
Techpowerup slip in 5500 in their 1650s review.
Tldr, perform similar to rx580.
While in other reviews, 5500 perform similar to 1650s.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13069771
Both of these cards really make no sense for the consumer?
Just spend a little bit more ($100 or so max) and you get something much better,  and even with RTX if you want to?
Or spend much less get a previous card and get almost the same performance!?
Just more stop gaps imo!
But of course it's great for manufacturers, people love "new" stuff and surely will upgrade soon enough when they learn their new,  cheap cards don't really cut it (in games like Cyberpunk etc)
-Scott Manley, 2021
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13070435
Why? These filled the low end range GPU.
$100 more is like 1660 Ti territory, it's not that much faster.
You can spend on last gen if it much cheaper but it won't be around for long since most already EOL. I'm not sure about AMD Polaris but Nvidia 1000 series EOL before 2000 series launch.
People that buy these cards usually doesn't need much GPU power, mostly only play e-Sport games.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13070571
If that's the case it's probably ok,  for me as a hardcore gamer these cards are completely useless - but I agree they obviously aren't aimed at people like me.
-Scott Manley, 2021
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13070584
34 minutes ago, masethekiller said:
RX 5500 review came out before release, same performance as RX 580. .
Interesting. I was under the impression that performance was on par/slightly better than a RX590? I'm wondering now if it would be worth upgrading to from a RX570...doesn't sound like it.
I only have a 1080/60 hz monitor and my RX570 runs games on mostly high settings just fine at 60 fps while overclocked. However, I'm looking for an AMD card that is able to more comfortably maintain 90 fps with Oculus VR titles. It works, but is certainly on the low end. I am finding that I'm having to run just about everything on low to medium graphics detail and frame rates will sometimes dip.
5500xt's are a bit out of my price range though =(
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13079557
You can read it on techpowerup.  It's very disappointing and I thought the 'rdna' architecture would make ATI more competitive.  They are coming with a 5500 XT maybe that will be much better but I doubt it considering how the 5550 is.
570 is not bad, I had a temporary 560 and it was ok, although it did not play far cry 5 or some more intensive games well. I have a 1660 Super now, its the best card in my opinion in terms of value now.  You could try a 1650 super, Nvidia has some really competitive cards now.  And I say that as someone who until recently always bought ATI.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13080590
  • 3 weeks later...
The 1550 XT is out.  Review on techpowerup.     It is not much of a better card as I predicted based on the 5500.
It's less fast than 1660 although marginally but for 10 dollars more you can get the 1660. The cheapest XT is 200 on newegg.  Also for 30-40 dollars more you can get the Super card which is significantly faster.
This is very disappointing from ATI, they are not offering a better performance or a better value.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13123919
4gb at 169$ is worth it, it beats a 1650 by decent margin, but 8gb at 200$ isn't, any 1660, especially the Super is better and its too close to the cost of those.  IMO if you have a budget card like this you are going to have to turn down setting in intensive games to get the fps high enough that its enjoyable, which reduces vram usage, so having 8gb is pointless for this card, especially with the current price.
Plethora of reviews came out today, feel free to check any or all of them out if you want. I watched all i could find and opinion above is what i've come to.
Last one has great bass boosted ASMR effect, don't agree with him about 8gb given other tests but eh who cares.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13124161
Performance in the reviews is right alongside the Rx 580.  In that way it doesn't seem like a functionally new product, but these companies have a habit of refreshing the packaging annually just to get the free advertisement from a new round of reviews. edit: I guess I'm having trouble setting aside my initial expectation that it would be at least 10% faster than the Rx 590.  The main "feature" seems to be that it does knock 80-100 Watts off the power consumption in exchange for a bit lower performance.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13124179
3 minutes ago, bkrownd said:
Performance in the reviews is right alongside the Rx 580.  In that way it seems like a useless product, but these companies have a habit of refreshing the packaging annually just to get the free advertisement from a new round of reviews.
Guys the RX 5550 =/= RX 5500XT
The RX5500 isn't on sale anywhere, its only for OEMs, the faster 5500XT is the one that launched today at 169$ for 4gb and 199$ for 8gb.  You're looking at the wrong card and the wrong benchmarks.
https://linustechtips.com/topic/1112931-radeon-rx-5500/#findComment-13124190
