Dual System Cases
Go to solution Solved by TVwazhere,
40 minutes ago, Budjet Tech said:
I was looking for a dual system case but could only find the evolve x, I was wondering if there were different case. Also in a new video from BitWit he mentioned that the Phanteks p400s is a dual system case but I could not find if this was true.
The P600S can, it's basically the Evolv X with different exterior panels.
Corsair 1000D
Enthoo Luxe 2
The aforementioned Evolv X and P600s
All of these secondary systems can ONLY be mITX, with only the Luxe 2 allowing the secondary system to have a separate GPU attached. So while they're "dual systems" theyre very limited compared to the Thermaltake Core W200 which can hold two full sized systems in the same case. Judging by the fact that you want a "normal" case, this probably isnt what you're looking for.
HP's Omen X is certainly big enough for it.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1112206-dual-system-cases/#findComment-12955160
The Enthoo Luxe 2 and Corsair... 1000D (I think) can also do it. @TVwazhere, resident case daddy, would know for sure.
Big =/= compatible. There's plenty of nice big cases I can't fit my SR-2 into (without modding) because they don't support the HPTX form factor, running dual systems is even more complicated than just a bigger board.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1112206-dual-system-cases/#findComment-12955167
Corsair 1000D
Enthoo Luxe 2
https://linustechtips.com/topic/1112206-dual-system-cases/#findComment-12955259
  • 3 years later...
Corsair 1000D
Enthoo Luxe 2
I use the P600s for a dual system, you're limited in the height of your GPU for the ATX system, but it's designed to use the vertical GPU mount and a longer riser cable for the m-ITX system
https://linustechtips.com/topic/1112206-dual-system-cases/#findComment-15720168
  • 2 weeks later...
Thank you for the correction 🙂
https://linustechtips.com/topic/1112206-dual-system-cases/#findComment-15734222
