Case needs
Go to solution Solved by TVwazhere,
If you have the bottom of the PC elevated with feet, you could hide a power button "under" the case (kinda like the mirror opposite of a top mounted power button)
Just now, Kingvogon said:
I'm designing a computer case at the moment and want your opinion. Does a modern computer need front i/o? Or anything in particular that you couldn't live without on the front of the case?
Power button. lol
But in all seriousness, I kind of hate front IO. I always pick my motherboard to have enough connections to never need to use the front IO. Plus I feel like it always ruins the look of a case. Not many cases look good with it. Please don't put aux or mic on the front. I'll stab you haha
I fix computers for a government that is garbage. I'm also a certified security professional according to Comptia
Using my paycheck on computer parts and alcohol and since this is a tech form I'll help with computer stuff I guess
https://linustechtips.com/topic/1109603-case-needs/#findComment-12932964
3 minutes ago, Dougarooo said:
Power button. lol
Thanks for the quick reply! Do you think you would be able to live without a power button on the front?
https://linustechtips.com/topic/1109603-case-needs/#findComment-12932980
As long as the power button is accessible it shouldn't matter IMO... unless you have the case itself less accessible (like under a desk or similar), then you would most likely need the button on the front.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1109603-case-needs/#findComment-12932986
Well where is it going? Top front. maybe. Bottom front? Is it even accessible? I like to think about options like where do people keep computers. Under desk, on desk, behind monitor, on shelf. What kind of limitations could come from me putting this button here. In what situation would having it here be an issue?
https://linustechtips.com/topic/1109603-case-needs/#findComment-12932988
Definitely needs headphone jack, microphone line in, USB 2.0 and 3.0 ports, possible a type C, a FireWire port, eSATA port and at least two 5.25" bays.
Joking aside, you do need to put a power button somewhere on the case, or at least behind a panel where it's easily accessible.  Unless you set up the BIOS to boot from keyboard.  The problem with that is that pets, and in particular cats, will regularly turn the PC on at night.
https://linustechtips.com/topic/1109603-case-needs/#findComment-12932995
Well it would be on the back of the case if i could get away with it but I hadn't thought about the back being inaccessible. Thanks for your help.
https://linustechtips.com/topic/1109603-case-needs/#findComment-12933006
10 minutes ago, Dougarooo said:
8 minutes ago, Captain Chaos said:
Definitely needs headphone jack, microphone line in, USB 2.0 and 3.0 ports, possible a type C, a FireWire port, eSATA port, at least two 5.25" bays.
Didn't even think about people having cats lol. Maybe a slightly hidden panel would work. Thanks for your thoughts.
Edited by Kingvogon
https://linustechtips.com/topic/1109603-case-needs/#findComment-12933009
Thanks for your thoughts! Definitely will consider that.
https://linustechtips.com/topic/1109603-case-needs/#findComment-12933029
https://linustechtips.com/topic/1109603-case-needs/#findComment-12937367
I just need a button and a usb accessible.
https://linustechtips.com/topic/1109603-case-needs/#findComment-12937565
On 10/5/2019 at 10:52 AM, Kingvogon said:
Dude! That's such a great idea!
I'd recommend making it a concave circle like most power buttons, or some sort of recognizable shape/texture since you'll need to feel around for it, but I think this is your best "hidden" but still relatively easy to access solution :)
https://linustechtips.com/topic/1109603-case-needs/#findComment-12948784
