Is my PC running too hot?
Go to solution Solved by Zando_,
3 minutes ago, KayPeters123 said:
EDIT: what do u mean by boost?
^^ That's what I was talking about, GPU Boost 2.0. I forget what Pascal does, IIRC most of the higher end cards will boost themselves to 1900-2000Mhz on their own, usually a good bit above what the spec sheet says, but GPU Boost is very temperature dependent. They boost the best at or under 50C, every step of the way from 60-70-80-etc it loses a bit of headroom due to clocking lower for thermal's sake.
You card is gonna be fine up to 85C, it just won't boost as high.
So i recently bought a PC from a custom PC builder, i chose the Coolermaster Masterbox Lite 5. I assumed that airflow would be decent enough for my specs untill a friend of mine told me there is not enough airflow for my specs?? i tried finding a decent review but all i could find was this guy shitting on it..
My specs are 8700K 1070TI 16GB ddr4. I used MSI afterburner to measure temps and my CPU stays around 75-85C while playing Gears 5. With spikes up to 87C. GPU doesnt get hotter than 81C
The CPU is even watercooled. So are these temps okay ornot? when i take front the front panel the CPU will cool down to approx 70C, while GPU temp stays roughly the same.
EDIT: perhaps i should note that the only time i saw it peak to 87C was when it went up to 100% load while loading up a battle on Total War three kingdoms. It cooled back off to 75 immediatly after
https://linustechtips.com/topic/1109307-is-my-pc-running-too-hot/
it's safe for your hardware, but if idle temps are high something's wrong
Don't forget to use the "Quote" feature or mention me ( @Gegger) if you want me to see your reply!
Community Standards // Forum Quickstart Guide // Floatplane // Forum FAQ // The Parrot Gang
Banned by Linus in the "banning game" thread who added insult to injury by putting this crap in my sig >(
WE ARE THE DARK SIDE Don't be a light theme peasant
             ........:oo:........
           o//ssssssssyhhysssss+////o               .''''''''''''''.
          mddmmm/::ddddddddddddddmmmyss::/mmN       |   PARTY ON   |
          o..+oodddmmmhhhhhhhhhhhdmmmmmdddooy       | ,............'
         h::oyyhddmmm+++///////////++++++mmmddy::s  |/
      Nyyo[[sddhyyyyy::::::::::::::::::::yyymmh//oyym
     h..:oohmm+:://///::::////////////////+mmmmms..sNN
     m++sddmmm+::hddhhy::+ddddddddddddddhhhmmmmmdhh+++d
    Nsssyyhmmhssooodmmhhh::+mmdyyyyyyyyddddddmmmmmmmmo::d
   mmd../mmmmmo::shhdmmhhh::+mmhooooooooyhhmmmmmmmmmmmyssdmm
  +++++smmdddo::///dmmhhh::+mmhooooooooooommmmmddddmmmdd/++m
 ``+hhhmmhoo/:::::oooooossymmhooooooooyyymmdoooooydddmmo//N
 ++:mmmmmy:::::::::::::/yyhmmhooooooooyhhmmd:::::+yyhmmyssddd
ooommmmmy:::::::::::::://ommhooooooooooommd:::::://shhdmm+..
yyhmmh++/::::::::::::::::+mmhooooooooyyymmd::::::::/++hmm+//
dddmmh++/::::::::::::::::+mmhooooooooyhhddh:::::::::::hmmysshhd
mmmmmdhhs::::::::::::::::+mmhoooooooohhhhhy:::::::::::hmmhhh``+
mmmmmh++/::::::::::::::::+mmdhhsooooodmm++/:::::::::::hmmsss``+
dddmmhoo+::::::::::::::::+dddddyssyyydmm::::::::::::::hmmsoo++o
dddmmdhho::::::::::::::::+hhdmmddddmmmmm::::::::::::::hmmsooNNN
mmmmmh///::::::::::::::::+hhdmmmmmmmmddd::::::::::::::hmmsoo++/
yyhmmdss+::::::::::::::::/ooydddmmmmmsoo::::::::::::::yddhyy::+
++ommmmmy:::::::::::::::::::ohhdmmddd/::::::::::::::::shhdmmsssNNNmmN
..+mmmmmy:::::::::::::::::::://shh+//:::::::::::::::::://dmmmmdoo+..o
``+dddmmhss+:::::::::::::::::::+++/::::::::::::::::::::::ooodddhhysshNNy++m ``+hhdmmdhhs///:::::::::::::::::::::::::::::::::::::::::::::yyymmmmmmmmo++hNNmdd ``+hhdmmdhhhhh+:::::::::::::::::::::::::::::::::::::::::::::::/hhhhhdmmmmmsoo... ``+ddmmmdhhhhhyyyyyyyyyyyo:::::::::::::::::::::::::::::::::::::+++++sdddmmdhhsss//+ ``+mmmmmhsshhhhhhhhhhhhhhy++/:::::::::::::::::::::::::::::::::::::::+ssyyydmmddd///hhd ``+mmmmmy::shhhhhhhhhhhhhhhhs:::::::::::::::::::::::::::::::::::::::::::::ymmmmmmmh../ ``+mmmmmy:://////////////ohhhyy+::::::::::::::::::::::::::::::::::::::::::///hddmmmhhs++s ``+mmmmmhssssssssssssssssydddddysssssssssssssssssssssssssssssssssssssssssssssdddmmmmmy::s ``+mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmhooh
7 minutes ago, will4623 said:
sounds a little hot but might not be the case. do you have all the fans installed?
Uhm i guess so the company i ordered it from promised to overclock the system while maintaning acceptable temps. all i have done is enabled User defined software automatic fan control on MSI afterburner. I have only opened the case once and that was to clean it. i do think all the fans work though
EDIT: i have never actually measured the IDLE temp nor do i know how to. all i know is when i start up a game the temps i see are around 40C
8 minutes ago, will4623 said:
how many fans did they include?
perhaps the fans are reversed. 85C watercooled its hot. not normal
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
perhaps. OP can you tell which way the fans are blowing?
I live in misery USA. my timezone is central daylight time which is either UTC -5 or -4 because the government hates everyone.
Well i checked it out. They are not reversed. I would not expect that from a professional PC building company either. Its not like it averages at 85C anyway. they are spikes, it rarely stays above 80C for longer than a second.
EDIT: with the front panel off it does not get hotter than 70C spikes. perhaps i should leave it off while gaming?
On my looped aggressive R7 1700 I hit 50c-52c while gaming for hours on end, temps are bad.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
That's fine, still well within safe temps. I'd only worry about 70-80C+ on the GPU because Pascal boosts less and less the hotter it gets, if you can keep it at 50-65C it'll boost much better. If you're not worried about those extra few MHz then it'll still be fine though.
Is the OP running a custom loop or an AIO?
Some 280mm AIOs struggle to cool the hotboi CPUs, whereas I built a system for a friend almost 2 years ago running a 6700K and R9 290X on a single 280mm rad with safe temps and it's still kicking with only one maintenance session about 6 months ago (dusting and a flush/refill of the loop cause my friend had time to bring it over). The difference between an AIO and properly done custom loop is pretty damn big. Pretty sure Bitwit did a vid running a full system on just a 240mm rad with one of the aluminum EK kits as well.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
Agreed, my 240mm AIO and its inability to handle mild overclocks over sustained times was the reason I decided to go loops on my machines.
Where do you see these temps, of 40c?   Idle temps are when the PC isn't doing anything, so look at the place you look at for the 40c.  That's the idle temp.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
Sorry im not quite sure what you are saying, ive been told that the 1070TI should be below 85C, I have never seen it go above 81C.
someone posted this
''The higher the temp the shorter the life of the card, now it is usually the capacitors on the card that fail and not the GPU itself, 75-85C is fine for a 5-8 year life span, depending on the card. Just make sure that the card never exceeds 91C that will fry your card. ''
Is he not correct? Why should i worry then?
Main PC
CPU: i5 12600KF
ODD: LG WH14NS40
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
Your temps would've been high for stock speeds but seem normal if the system is already oc'ed.
