Need help choosing between 2 similar laptops?
Solved by Lennart van de Merwe,
5 minutes ago, AhICanNotThinkOfAUsername said:I'm planning on using it for college, mainly for studding and working with AutoCAD, also a little bit of gaming.
Aight chief, choose the ryzen 7 model. You aren't going to be doing heavy AutoCAD on either, but it's possible. If it is possible, you can upgrade to 16 gigs later.
remo233 ·
Posted in CPUs, Motherboards, and Memory4 -
RTX 3090 ·
Posted in Programs, Apps and Websites1 -
7
7
porina ·
Posted in New Builds and Planning16 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7 -
Ricodotsh ·
Posted in New Builds and Planning15
