Help with my Javascript Adventures
Go to solution Solved by FezBoy,
The way switches.are evaluated is different to that of ifs.  You shouldn't have foo===bar in a case, you would do switch (Foo){case: bar}
This unfortunately make it difficult to check if something is positive, negative, or zero.  I think that an if else chain would be your best bet.
Scratch that, try this:
Quote
switch (Math.sign(sleepDebt)) {
    case 0:
      return('You got the perfect amount of sleep!');
    case 1:
      return('You should get some rest!');
    case -1:
      return('You got more sleep than needed!');
    default:
      return('Check your code dude!');
Math.sign(foo) returns -1 for foo<0, 0 for foo===0, and 1 for foo>0.  The switch statement compares that to 0, -1, or 1 to determine which path to take.
(Please excuse mobile formatting)
See the MDN:
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Math/sign
https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/switch
So far I've really enjoyed learning Javascript. It's an awesome problem solving challenge where you need to pay great attention to detail.
However I ran into a bump and I'm not sure how to handle it.
I have this block of code as part of a project for a 'Sleep Debt Calculator':
// This first function serves only the purpose of storing daily sleep hours in a week.
const getSleepHours = day => {
  day = day.toLowerCase();
  switch (day) {
    case 'monday':
      return 8;
    case 'tuesday':
      return 7;
    case 'wednesday':
      return 6;
    case 'thursday':
      return 5;
    case 'friday':
      return 4;
    case 'saturday':
      return 3;
    case 'sunday':
      return 2;
    default:
      console.log('Error: Invalid Day')
// These next two arrow functions are the ideal number of hours in a week (h in a day * 7) and the actual number of hours (sum of each day's hours)
const getActualSleepHours = () => (getSleepHours('monday') + getSleepHours('tuesday') + getSleepHours('wednesday') + getSleepHours('thursday') + getSleepHours('friday') + getSleepHours('saturday') + getSleepHours('sunday'));
const getIdealSleepHours = () => {
  const idealHours = 8;
  return idealHours * 7;
// This is where the meat and potatos are. This is where the problems begin, apparently.
const calculateSleepDebt = () => {
  let sleepDebt = (getIdealSleepHours() - getActualSleepHours());
  switch (sleepDebt) {
    case sleepDebt === 0:
    case sleepDebt > 0:
    case sleepDebt < 0:
    default:
console.log(getActualSleepHours());
console.log(getIdealSleepHours());
console.log(calculateSleepDebt());
Now as of right now, running the code will log the following into the console
35
56
Because the last string relates to the calculateSleepDebt variable, it seems as though the switch statement is evaluating on sleepDebt not being equal, greater or lower than zero. However if I change the block to this:
  console.log(sleepDebt) // This allows me to see the value of sleepDebt in the console
    case sleepDebt > 0:
    case sleepDebt < 0:
    default:
Then I can clearly see that the value of sleepDebt is 21, which is correct.
So there's gotta be something wrong with my switch statement, but I'm stumped. What did I write wrong, I wonder?
As always I really appreciate all your guys' help :)
EDIT: I was able to run the code just fine with a chain of if-else statements. However I'm interested in whether I can write this with a switch statement because a) it's less keystrokes and each keystroke counts when you're coding against the clock, and b) as a mathematician, case x = 0 / case x > 0 / case x < 0 is a very common, very intuitive notion that's used in a vast majority of math theories.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/1105684-help-with-my-javascript-adventures/
Three =-signs means check the value + type of variable. Perhaps the 0 you mention there is not a variable of the type of 'let', but perhaps an int by default?
Normally I would say "just hover over the 0 in your IDE and see what the variable type is", but I am not sure if there is an IDE for JS that supports this.
Quote
    case 0:
    case 1:
    case -1:
    default:
See the MDN:
Edited by FezBoy
Further developments
Resident Mozilla Shill.   Typed on my Ortholinear JJ40 custom keyboard
               __     I am the ASCIIDino.
              / _)
     _.----._/ /      If you can see me you
    /         /       must put me in your
 __/ (  | (  |        signature for 24 hours.
/__.-'|_|--|_|
JavaScript is very loosely typed.  "let" is not a type, rather an alias for "var". Neither defines any type.
Note: var and let are NOT the same but are often treated as such.  Car declares global variables, whereas let is local.
Var: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/var
Let: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Statements/let
Scope: https://developer.mozilla.org/en-US/docs/Glossary/Scope
Type: https://developer.mozilla.org/en-US/docs/Glossary/Type
              / _)
/__.-'|_|--|_|
The definition of === would be:
Quote
equal value and equal type
https://www.w3schools.com/jsref/jsref_operators.asp
What I was thinking, is that javascript is looking at 'let sleepDebt' contains the same as '0' (an int presumably), but it's a variable of a different type, thus would still return false.
But that was just a feeling, not something from experience I could mention.
Thank you guys. Programming feels like black magic when you're  just starting out lol.
Computer Specs:
1 hour ago, camjocotem said:
It IS black magic I'm afraid but you learn to accept it ?
No, it being black magic is good.
Computer Specs:
among other things , LET is block scoped, meaning its scope exists only between { }
var a = 1;
var b = 2;
if (a== 1) {
  let x = a + b;
  console.log(x);  // prints 3
console.log(x); // ReferenceError: x is not defined
use developer tools to see console.  the second console.log will give error or undefined because x only exists inside the if
also let will not allow you to recreate the variable, it will say it already exists and your code will fail.
you can't say let a = something; more than once in a block/function etc
var a = 1;
var b = 2;
if (a== 1) {
  let x = a + b;
So I'm just starting the scope lesson tonight, and what you say makes sense. I'll remember to use let when I want a variable to only be usable inside a function.
Fun times!
Computer Specs:
