My motherboard only has one PCIe slot (occupied by the graphics card; I cannot change the PCIe slot configuration with risers/etc/whatever due to case limitations), and one M.2 x4 slot which I'm currently using.
Would it ever be possible to cram a second M.2 SSD into my system? Only having x2 capability is fine; I don't want M.2 SATA
Specifications:
Ryzen 5 1500X
ASRock B450 Gaming ITX/AC
16GB DDR4
Optane 800P 58GB M.2 SSD
Patriot Burst 240GB 2.5" SSD
Toshiba Q300 240GB 2.5" SSD
Sapphire RX 570 PULSE 4GB
beQuiet SFX Power 2 400W
Silverstone ML08B
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1104052-how-do-i-fit-an-extra-m2-into-my-system/
Just now, 5x5 said:
Nope,.you are out of PCIe slots so you can't really get an expansion card
The only thing I could do was plug in a M2->PCIe adapter into the M.2 slot, and then into that PCIe slot a card which supports multiple NVMe SSDs
No, your options here are only SATA to M.2 or USB to M.2. Should have picked a motherboard with more slots.
This would not work. For this to work the motherboard must support PCI_e Bi-furcation of which is primarily a server feature not found on most desktops. Even then the M.2 slot may not support being divided like a PCI_e slot further making this not possible.
Get rid of the Optane and get a higher capacity, fast NMVE storage instead.
Not only are you on AMD so it's not performing it's best with StoreMI, but you don't even have a HDD to accelerate with Optane. The performances is negligible with a SSD compared to simply getting a 3000MB/s NVME drive.
CPU: AMD Ryzen 3700x / GPU: Asus Radeon RX 6750XT OC 12GB / RAM: Corsair Vengeance LPX 2x8GB DDR4-3200
MOBO: MSI B450m Gaming Plus / NVME: Corsair MP510 240GB / Case: TT Core v21 / PSU: Seasonic 750W / OS: Win 11 Pro
The Optane is being used as a boot, programs and small games drive, not an acceleration drive.
Optane Memory or M10 drives are for acceleration, Optane H10 drives are SSD+Optane combos and Optane 800P, 900P and 905P is Optane SSD (aka an actual SSD).
