The best graphic card for playing LOL and CSGO only with max setting?
j2ee
Resolution and Freshrate?
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
3 minutes ago, Slottr said:
Resolution/refresh rate?
1080, 60
3 minutes ago, 5x5 said:
Whole system?
windows 10 64bits, cpu not decided yet. 16GB ram.
Resolution, Refresh rate? I think that a 1060 3gb or a 1650 would do just fine for a 144hz display i think, look up on youtube for a benchmark.
edit: or a rx 570
Just now, j2ee said:
1080, 60
I guess a 570 would do fine
Kinda hard to say without a cpu. Those games are more dependent on that.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Give us a budget and country. Well price out a system for you.
Inb4 he buys a Pentium D ?
With Freesync / G-Sync? Or powerful enough for smooth 60fps with Vsync on?
I totally agree without much tweaking youll get your 60fps and it will be sustained with a 570 or nVidia equivlant.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
AMD graphic card like 570 is more buggy than Nidvia like 1650?
I bought a 570 8GB for my friend and he games a lot.  Many different games from AAA to RPG element FPS games.  He has not had a single issue.  We didn't even install windows we just booted up with new hardware and it worked just fine and no video issues.
No? What are you talking about. The 1650 is a horrible value card. Don't waste money on that thing
RX460 or RX470/570
Or....some older stuff because it's cheap.
Don't buy a NEW priced GPU for these types of titles, get what you say you need.
Aim higher when you can justify it,.with say a high refresh panel,.. or other factors/needs change.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://gpu.userbenchmark.com/
sort by value%, 1650 is still the best 5 top value.
Not for me? There is the 1660 on the top if being sorted by user rating. If I sort by value the RX 570 is at the top.
Don't use that meme of a site lol. Seriously, look at the news topic about userbenchmark and you will understand why we laugh at it and don't take it remotely seriously
RX570 and at least 4 core cpu is already enough. even 8gigs enouhg
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
I think around 85% people use Nidvia but not AMD for a good reason...and 1650 is newer then it would have longer support
Yeah, because they were way behind in the past years. Using a 5700 XT myself. There's no reason not to go team red unless you really want (and can afford) the most powerful card on the market. It also gives you the option to buy a Freesync monitor later, which usually are way cheaper than G-Sync.
They also pair great with the current mid-range king CPU (Ryzen 5 3600). ?
You're in a tech forum full of tech nerds, why do you want to act smart if you know nothing?
People in this forum are not that technical, try overclock.net
I just read this and don't think this ranking site has any issue:
