Posted September 6, 2019 I recently purchased this 2U JBOD system here on a Scratch & Dent deal. As far as I've seen so far the chassis itself is completely free of marks but the PSU grill that protects the fan is completely smashed in and the fan is wreaked. I didn't really trust the PSU to begin with so I want to replace it. Due to the 2U form factor the PSU must use an 80mm fan on the front/back it cannot use a 120mm top/bottom fan. It'd be completely suffocated. Does anyone know of a well branded PSU that meets this spec? One that's not considerably overpriced for the wattage? I'm looking for ~400W with ~30+A on the 12V rail. Worst comes to worst I'll buy an SFX PSU and just make a custom bracket for it. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 @LukeSavenije Don't you know some Delta's that might fit his usercase? Personal Desktop": CPU: Intel Core i7 10700K @5ghz |~| Cooling: bq! Dark Rock Pro 4 |~| MOBO: Gigabyte Z490UD ATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: RX 6900XT Sapphire Nitro+ |~| PSU: Corsair TX650M 80Plus Gold |~| Boot: SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro. Luna, the temporary Desktop: CPU: AMD R9 7950XT |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Aorus Master |~| RAM: 32G Kingston HyperX |~| GPU: AMD Radeon RX 7900XTX (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver) Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12871787 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 4 minutes ago, Princess Luna said: @LukeSavenije Don't you know some Delta's that might fit his usercase? you'd get into the server parts of delta at that point... that'll cost a lot more than that sfx plan Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12871799 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 Author 16 minutes ago, LukeSavenije said: you'd get into the server parts of delta at that point... that'll cost a lot more than that sfx plan I'm not particularly worried about redundancy. The pool is only ever going to exist on the JBOD box if it goes offline because it needs a PSU swap no biggie. Plus backups are always going to exist else where on the network, to further state it's not a huge issue. Thinking more and more about it I do have one SFX PSU around, I might just be able to swap it for an ATX then use it in the server. But if we can find a more appropriate ATX unit for ≤$75 that'd be great. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12871839 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 well... from taking a bit closer look... i think it's a flex atx... that's not going to be easy I'm thinking about the few units fsp has for this so far Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12871850 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 Author 15 minutes ago, LukeSavenije said: well... from taking a bit closer look... i think it's a flex atx... that's not going to be easy I'm thinking about the few units fsp has for this so far In the photos? It's standard ATX. Server is a 2U. However I forgot about the existence of FlexATX. That'd get the job done. Some don't appear all that expensive. I can make a bracket to convert ATX to FlexATX. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12871870 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 54 minutes ago, Windows7ge said: In the photos? It's standard ATX. Server is a 2U. However I forgot about the existence of FlexATX. That'd get the job done. Some don't appear all that expensive. I can make a bracket to convert ATX to FlexATX. well, good luck finding whatever psu you need... at least now you know a bit where to look for, and I'll just be here whenever you want to show some units you found Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872006 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 First off: That's a Zippy PSU. One of the best PSU OEMs out there. Might even consider just swapping out the fan. Second: It's a standard ATX PSU. Not 1U, 2U or Flex. Just good ol' PS/2 / ATX. Not even the connectors are proprietary. Thirdly: That's not a 2U chassis. That's a 3U chassis. Almost anything will fit in there. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872120 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 27 minutes ago, jonnyGURU said: First off: That's a Zippy PSU. One of the best PSU OEMs out there. Might even consider just swapping out the fan. Second: It's a standard ATX PSU. Not 1U, 2U or Flex. Just good ol' PS/2 / ATX. Not even the connectors are proprietary. Thirdly: That's not a 2U chassis. That's a 3U chassis. Almost anything will fit in there. Not 100% sure on the last one. If a 1U server is a little thicker than a 40mm fan, then a 2U should be a little thicker than an 80mm fan, which looks to be the case here. I'd definitely agree with the fan replacement route though, Looks to be an NMB 12v 300mA fan, which should be super easy to find a replacement for if OP is comfortable doing a fan swap. Donate your unused computer resources for cancer and other research. For Zinsey ❤ Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872184 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 Author 32 minutes ago, jonnyGURU said: First off: That's a Zippy PSU. One of the best PSU OEMs out there. Might even consider just swapping out the fan. Second: It's a standard ATX PSU. Not 1U, 2U or Flex. Just good ol' PS/2 / ATX. Not even the connectors are proprietary. Thirdly: That's not a 2U chassis. That's a 3U chassis. Almost anything will fit in there. 1) I don't know if it was pressure or blunt force trama. I'm not against getting a hammer and banging out the metal to replace the fan but if the PSU was dropped hard to cause this I don't think it matters if zippy made it it shouldn't be used. 2) When I say 2U I'm only referring to the enclosure. I'm aware the PSU itself is standard ATX. 3) This goes against my understanding of U's. It's 1/2 the hight of my 4Us and is marketed as a 2U. If you say it's a 3U I'm willing to hear your argument as to why. And yes I'm aware any ATX/PS2 PSU will fit the issue is there's no room for PSUs with 120mm intake fans to get air. There's no gap top nor bottom the PSU would suffocate. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872192 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 6, 2019 Author 1 hour ago, iamdarkyoshi said: I'd definitely agree with the fan replacement route though, Looks to be an NMB 12v 300mA fan, which should be super easy to find a replacement for if OP is comfortable doing a fan swap. I'm not 100% against it, wouldn't be the first time I cracked open a PSU definitely wouldn't be the last. My main concern is just how the damage occurred but I'll tell the two of you what, tomorrow I'll crack it open and take pictures of the PCB. If you guys don't see anything that looks like it was dropped from a hight (cracked solder joints, cracked PCB, bent components, surface mount chips snapped off) then I'll hammer out the housing and replace the fan. I most likely wouldn't replace it with a identical one though. I have a small pile of random 80mm fans. If it's 12V I'll solder a old one to the original fans cable. I will say though if it dies and takes some of my equipment with it I'm blaming both of you. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872340 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 2 hours ago, Windows7ge said: 2) When I say 2U I'm only referring to the enclosure. I'm aware the PSU itself is standard ATX. I was talking about the enclosure (chassis) as well. It doesn't look like a 2U and I haven't seen a 2U that accepts standard ATX PSUs. This looks like a 3U. 2U's are only 3.5" tall. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872421 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 49 minutes ago, jonnyGURU said: I was talking about the enclosure (chassis) as well. It doesn't look like a 2U and I haven't seen a 2U that accepts standard ATX PSUs. This looks like a 3U. 2U's are only 3.5" tall. 2U on the spec page. http://www.istarusa.com/en/istarusa/products.php?model=MAGE212U40-PCI-E It makes sense, 1U servers use 40mm fans, 2U uses 80mm fans, which is what is inside a standard ATX PSU. As for inspecting the PCB for damage, it sounds like a good idea. I have had a gateway PSU that took a fall and the transformer broke off the board. Donate your unused computer resources for cancer and other research. For Zinsey ❤ Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872498 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Author 1 hour ago, jonnyGURU said: I was talking about the enclosure (chassis) as well. It doesn't look like a 2U and I haven't seen a 2U that accepts standard ATX PSUs. This looks like a 3U. 2U's are only 3.5" tall. Close enough. I knew I bought a 2U. I'll crack open this zippy PSU and inspect the extent of the damage. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872527 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Haha! Ok. My bad. Back in my day, you only saw PS2 PSUs in 3U and up. Pretty cool it's a 2U that uses a PS2 PSU. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872531 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Author 15 minutes ago, jonnyGURU said: Haha! Ok. My bad. Back in my day, you only saw PS2 PSUs in 3U and up. Pretty cool it's a 2U that uses a PS2 PSU. Cool yes, limiting my options, also yes. Look here: It is perfectly the hight of the interior of the enclosure. The PSU cannot be any thicker at all or else the lid won't go on. Which reiterates my point of suffocating a replacement PSU if it relies on a gap (one a 3U enclosure would EASILY provide - if I was working with a 3U I would not have posted this topic). Give me a minute while I take this PSU to bits. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872566 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Author @jonnyGURU @iamdarkyoshi Alright, got it torn apart and wow you wernt lying about zippy PSUs this thing is built like a tank. Filtering capacitors on the AC input (both box film & ceramic), bleed resistors, extra solder on almost every trace for current carrying and thermal dissipation, thermal probes, proper spade connectors, proper double throw switch (for live & neutral), extra PVC insulation on the wires, everything's glued to everything else, PCB held to the enclosure with lock washers, she's built to last. I was going to take pictures but there's simply far too much circuitry to go over. I inspected as much as I could especially where the fan got pushed into the PCB and everything appears solid. PCB isn't cracked. Nothing's loose that I could find. Nothing looks bent or pushed. That grill turned out to be soft enough for me to push back into place with my hands. I replaced the fan with a random old but never used 12V 0.25A 80mm fan. I know it doesn't move as much air as the original but for what I paid if a damaged fan is the only thing wrong with it it was a heck of a deal. What I've done is put the box back together and thrown a few HDDs in it and I'm going to let it run overnight. See if it overheats, or let's out the magic smoke, if it's fine then I'll take a gamble that it will still do it's job because the inside of that thing was impressive. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872815 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 1 hour ago, Windows7ge said: -snip- Pretty much exactly what I would have done. The 50mA difference on the fan really shouldn't be an issue. Worst I could see happening is it runs a tad warmer and the fan controller increases the speed to compensate, assuming it has speed control. My guess is someone slid it into a rack and there was a cable behind it like a power cable and it dented the fan in. Dunno. Either way it sounds like it's back up and running, overnight test should give us an answer as to if it survived. Donate your unused computer resources for cancer and other research. For Zinsey ❤ Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12872866 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 14 hours ago, Windows7ge said: Cool yes, limiting my options, also yes. Look here: It is perfectly the hight of the interior of the enclosure. The PSU cannot be any thicker at all or else the lid won't go on. Which reiterates my point of suffocating a replacement PSU if it relies on a gap (one a 3U enclosure would EASILY provide - if I was working with a 3U I would not have posted this topic). Well.. it shouldn't be impossible to find a modern PSU with push/pull if this Zippy weren't to work out. I know FSP and Cougar (HEC) still have some units on the market. And they still use them in China for iCafe gaming PCs that use "desktop" (not tower) cases similar to your 2U or 3U. I believe Great Wall and Huntkey are making those units. But if the Zippy works, go with it. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12873806 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Author 13 hours ago, iamdarkyoshi said: assuming it has speed control. That's actually the one thing I don't like about this PSU. It only uses a 2 wire fan. Now it could just be directly driving the motor by limiting the input voltage and reading off the thermal probe but I think that's a but crude so I think it's just set to run 12V 100% of the time. 2 hours ago, jonnyGURU said: Well.. it shouldn't be impossible to find a modern PSU with push/pull if this Zippy weren't to work out. I know FSP and Cougar (HEC) still have some units on the market. And they still use them in China for iCafe gaming PCs that use "desktop" (not tower) cases similar to your 2U or 3U. I believe Great Wall and Huntkey are making those units. But if the Zippy works, go with it. Hard to find, no. Hard to find from a reputable brand without being exorbitantly overpriced yes. If the zippy should die pre-maturely (and hopefully not take anything else with it) I'll look into those brands. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12874240 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 7 minutes ago, Windows7ge said: That's actually the one thing I don't like about this PSU. It only uses a 2 wire fan. Now it could just be directly driving the motor by limiting the input voltage and reading off the thermal probe but I think that's a but crude so I think it's just set to run 12V 100% of the time. Crude? FYI: 99% of power supplies on the market today use two wire fans that are controlled via varying DC voltage controlled by a thermistor based controller. The only reason to use PWM is if you need the granular speed control that allows a fan to spin well below what would be a normal startup voltage for a DC fan. And for a "server" PSU, "low noise" is not a sought out feature, so there's no reason to add the cost of PWM. And even when PWM fans are used, I've never seen the fan controller use the tach wire to report back to the controller. Even when an MCU is used to control the fan. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12874265 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Author 2 hours ago, jonnyGURU said: Crude? FYI: 99% of power supplies on the market today use two wire fans that are controlled via varying DC voltage controlled by a thermistor based controller. The only reason to use PWM is if you need the granular speed control that allows a fan to spin well below what would be a normal startup voltage for a DC fan. And for a "server" PSU, "low noise" is not a sought out feature, so there's no reason to add the cost of PWM. And even when PWM fans are used, I've never seen the fan controller use the tach wire to report back to the controller. Even when an MCU is used to control the fan. Calm down there it's just an option. I understand the concept of if it can be done simpler than it should be but you would think with RPM reporting & PWM that the extra few dollars it costs to include would be offset by the $200+ prices I see similar wattage units going for. I would say though with only two wires it can't report a fan failure. Not unless it went open-circuit. Of course your argument to that will be if that happens in a business environment you just replace the PSU but the issue is how do you know it failed when it can't tell you other than shutting down from overheating? Kind of makes RPM reporting a worth-while feature so it can notify you even if it's only driven directly by limiting DC voltage so I do find that a bit crude. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12874620 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 1 hour ago, Windows7ge said: Calm down there it's just an option. I understand the concept of if it can be done simpler than it should be but you would think with RPM reporting & PWM that the extra few dollars it costs to include would be offset by the $200+ prices I see similar wattage units going for. I would say though with only two wires it can't report a fan failure. Not unless it went open-circuit. Of course your argument to that will be if that happens in a business environment you just replace the PSU but the issue is how do you know it failed when it can't tell you other than shutting down from overheating? Kind of makes RPM reporting a worth-while feature so it can notify you even if it's only driven directly by limiting DC voltage so I do find that a bit crude. I'm curious as to what you use for a desktop PC PSU. Fan fail alarms is something simply not implemented in ATX power supplies as they're not meant for mission critical application. Literally none of the ATX PSUs on the market have that feature. Like I said: Even when a PWM fan is implemented, there's no reporting back to the fan controller of fan status. Those sort of features are typically reserved for server specific PSUs. Simply put, the way the circuit works is if the fan doesn't spin, the PSU gets hotter, and eventually OTP kicks in and shuts the PC down. Again: NOT good for mission critical systems. Ironically, even the ATX PSUs that have RPM fan speed reporting can't tell the difference between a failed fan and a fan that's not spinning because it doesn't need to. So unless you're actually looking at the reporting software to see if the fan is spinning or not, you have no idea if the fan has failed. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12874738 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2019 Author 2 minutes ago, jonnyGURU said: I'm curious as to what you use for a desktop PC PSU. Fan fail alarms is something simply not implemented in ATX power supplies as they're not meant for mission critical application. Literally none of the ATX PSUs on the market have that feature. Like I said: Even when a PWM fan is implemented, there's no reporting back to the fan controller of fan status. Those sort of features are typically reserved for server specific PSUs. Simply put, the way the circuit works is if the fan doesn't spin, the PSU gets hotter, and eventually OTP kicks in and shuts the PC down. Again: NOT good for mission critical systems. Ironically, even the ATX PSUs that have RPM fan speed reporting can't tell the difference between a failed fan and a fan that's not spinning because it doesn't need to. So unless you're actually looking at the reporting software to see if the fan is spinning or not, you have no idea if the fan has failed. A Corsair AX1200i but that's besides the point. I'm only referring to server PSU's. I don't expect a desktop one to sound a buzzer and light up an LED next to some text that says PSU fan failure (although that would be nice). I would think even if it is using the ATX form factor that a server PSU brand would include server PSU features. A lot of 1U/2U servers from brands like Dell or HPE include indicators for when case fans fail so it's something I would have liked to see considering the server application of the device. Guides & Tutorials: PROXMOX - Rebuilding ZFS RAID rpool After Disk Failure Mass Deploying Customized Windows 10/11 Installs Building a GNU/Linux Based Windows Deployment Server GNU/Linux Installer Server: Installation & Configuration How to: Use (i)PXE to Install Windows from a Network Why Memorize IP's When You Can Self-Host DNS Instead? Ventoy - The USB Multi-Boot Utility! Introduction to PXE/iPXE Network Boot Featuring FreeBSD & Ubuntu Server Don't see what you need? Check the Full List or *PM me, if I haven't made it I'll add it to the list. *NOTE: I'll only add it to the list if the request is something I know I can do. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12874757 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 8, 2019 2 hours ago, Windows7ge said: A Corsair AX1200i but that's besides the point. I'm only referring to server PSU's. I don't expect a desktop one to sound a buzzer and light up an LED next to some text that says PSU fan failure (although that would be nice). I would think even if it is using the ATX form factor that a server PSU brand would include server PSU features. A lot of 1U/2U servers from brands like Dell or HPE include indicators for when case fans fail so it's something I would have liked to see considering the server application of the device. Most of Zippy's server PSUs have that feature. This Zippy ATX PSU is a corner case. It was built for a US company to market a cheap server chassis. Link to comment https://linustechtips.com/topic/1102015-in-need-of-a-replacement-psu/#findComment-12874984 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
