It depends what you are using it for.
I7 9700k and 2080ti for gaming
I9 9900k and 2080 super for workstation stuff. I would also recommend a higher end AMD chip if you are doing any workstation tasks in place of the 9900k.
Both choices are very good, I don't think you'd be disappointed either way you go. It comes down to preference.
https://linustechtips.com/topic/1101709-which-parts-to-choose/#findComment-12869122
