My mom wants a laptop to do CAD work. The budget is around 2000 but can go higher. The programs being used are 2020 design and maybe fusion 360.
https://www.amazon.com/gp/product/B07QRGSFS7/?tag=thowisguy-20
This is one that im considering but idk if a quadro laptop would be better.
https://linustechtips.com/topic/1101704-laptop-for-cad/
19 minutes ago, 5x5 said:
That's a pretty poor option. Get a proper business workstation like the Lenovo ThinkPad P53 - https://www.lenovo.com/us/en/laptops/thinkpad/thinkpad-p/P53/p/22WS2WPWP53
the rtx 4000 model is $3500 which is above budget and the T2000 is half the performance. also i think 2020 design and fusion 360 are both optimized for directx not openGL so geforce cards might actually run better than quadro
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12869113
Thing is - a gaming laptop will be loud, hot and won't last past 2 years in most cases. It's not made for professional work, stability or long-term durability
A professional machine is FAR more durable and reliable - the P53 is built to military standards, offers good cooling at very low noise levels while also maintaining high performance. It's water resistant, dirt resistant, sand resistant, high-impact resistant, drop resistant and etc - it's designed to work in almost any condition - from a dusty desert to a frozen arctic station. It offers far superior security and comes with NBD support for 1-day turnaround times in the case of issues. Not to mention it comes with certified drivers and firmware for 0-bug/problem operation.
Basically - if your mother wants a laptop for work - look at the business class. If you want to be constantly fixing bugs, issues and and constant overheating - then I won't stop you, waste the money on a flashy gaming laptop with a GeForce card and just buy a new one when it inevitably dies in 2 years due to the extreme heat it produces and can't cool when under heavy stress.
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12869190
I agree with getting a ThinkPad. If you don't mind refurbished, a P52 with a Quadro P3200 (6 GB VRAM) should still be very solid. I found you a P52 with a Quadro P3200 for $1600 on eBay. i7-8850H CPU, 64 GB of RAM, and a 512 GB SSD.
Edited by panzersharkcat
P3200, not 3200
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12869885
arent quadros are optimized for openGL but both of the programs seem to use directx. is there a business laptop with geforce card
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12871087
Quadros are optimized for reliability and stability. Not OpenGL. They also come with ECC Vram
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12871091
Yes but the ones I know have the 1050 Ti or the 1650, which don't seem to be powerful enough for your mom.
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12871183
Also take a look at MSI Workstations:
Custom Built MSI WE65 9TJ-006 - 15.6" FHD - i7-9750H - Quadro® T2000
Custom Built MSI WE75 9TK-875 17.3" FHD - E-2176M - Quadro® RTX 3000
Custom Built MSI WS65 9TL-686 - 15.6" FHD - i7-9750H - Quadro® RTX 4000
Custom Built MSI WS65 9TM-857 - 15.6" UHD - i7-9750H - Quadro® RTX 5000
Razer Blade 16 | AMD Ryzen AI 9 HX 370 | 64 GB LPDDR5X 8000 MHz RAM | GeForce RTX 5090 24 GB GDDR7 VRAM | Samsung ATNA60DL04-0 16" QHD+ 240Hz OLED Display + AOC Q27G3XMN 27" QHD Mini LED Monitor | WD_BLACK SN850X 4TB+8TB SSD | MediaTek Wi-Fi 7 MT7925 WLAN | Windows 11 Pro
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12871338
https://www.nvidia.com/Download/driverResults.aspx/145178/de-de
https://www.nvidia.com/en-us/geforce/news/creator-ready-drivers-supercharge-creative-apps/
also nvidia does have drivers optimized for creators for geforce.
and a lot of people on the autodesk forum cite that the reason why quadro performs better in some cad programs like solidworks is the openGL optimizations
Quote
Recommended Hardware Specifications
Processor: i7 – 8th Generation (Quad Core) or AMD Ryzen7 models
System Memory: 16 GB RAM
Hard Drive: SSD with 20 GB free disk space for installation
Video Card: DirectX 11 compatible dedicated video card (such as GTX1080)
Optical Drive: DVD-ROM. A DVD-ROM is required to install 2020 Design and catalogs when Internet access is not available.
Security Device: Free USB port for the 2020 Design license (dongle). For Cloud (soft key), the USB port is not needed.
https://www.2020spaces.com/2020products/2020design/system-requirements/
2020 design seem to work fine with a gtx card
so the question now is fusion 360 and a lot of people on the autodesk forums say geforce cards work better than quadro cards because of fusion being directx
https://forums.autodesk.com/t5/fusion-360-design-validate/fusion-invento-quadro-2000m-or-gtx1060/td-p/7561220
also we are not going to be running anything for days so i dont think the ECC ram is needed
i think you have a good point in that the professional laptop will probably last longer but i think gaming laptops breaking in 2 years i only true for razer.
https://rog.asus.com/articles/technologies/inside-our-hardcore-rog-durability-tests/
it seems that asus do durability tests and searching around people say that they last 4-7 years
if it was me i would be willing to spent the extra 1500 just for the lenovo keyboard :P but i dont think my mom would be quadro cards are just too expensive
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12871400
If you're set on GeForce, then just pick up an X1 Extreme - business-class in every way but with a GeForce and Core CPU rather than Quadro and Xeon
https://linustechtips.com/topic/1101704-laptop-for-cad/#findComment-12871403
