Is this hard drive cage is compatible with my Corsair 500D case?
Solved by Corsair Nick,
@Elven - 500D won't be compatible with the cages you referenced. There are no mounting locations under the PSU shroud, or in the front section of the case for an additional cage. If you plan to go with SSD's for RAID, then you have some options like the following to increase your 2.5" drive count:
