Hi. I'm building my first computer and my budget is around 400 dollars to 450 dollars. I want to get a case called the Deepcool Matrexx 55 and its 50 dollars right now. should I be spending more or less on this case? is this a good case for my first build or should i get something different? also how do I tell if cases cant fit micro atx motherboards because i read somewhere online that some mid tower cases are stupid and are not compatible with micro atx.
https://linustechtips.com/topic/1097019-case-question/
so...what exactly are you going for?
400-450 is an extreme budget build...enough of one..that Case/PSU and anything else you don't need to buy together should be picked up while on sale...possibly with Mail-in Rebates....
Location ish? Games? programs?
What monitor  resolution/hertz do you have?
https://linustechtips.com/topic/1097019-case-question/#findComment-12832270
https://linustechtips.com/topic/1097019-case-question/#findComment-12832287
I'm not aware of any cases that are ATX that cannot fit mATX motherboards, so long as they're not a proprietary case like an HP, Lenovo or Dell prebuilt which sometimes use their own motherboards. ATX shares many of the same screw mounts as mATX, plus uses more PCI-E slots so I cant think of a reason it wouldnt fit.
The case comes with 0 fans, and even for a $450 build I'd recommend at least one fan, regardless if it's intake or exhaust.
https://linustechtips.com/topic/1097019-case-question/#findComment-12832875
