Best case for airflow
Solved by TVwazhere,
56 minutes ago, kumigidax said:I've found the Cooler Master Mastercase H500M, which is rather on the expensive side but that's my limit. Is this case any good? Or do you have any other suggestions?
It's good, but your'e right it's very expensive. the Mastercase H500 has 100% of the airflow of the H500M for half the price. There's also cases like Meshify C, Enthoo Pro M TG, Focus G and Masterbox MB511 RGB just to name some of the more popular cases.
