Cooling pad vs stand: does one affect thermals better than the other
ishraqiyun77
Haven't really seen any scientific comparisons of this done and I'm too lazy to do them myself.
Anyway, just seeing if a cooling pad with fans that a laptop sits on does produce lower thermals in a laptop as opposed to just a stand that allows ventilation like the following:
https://www.amazon.com/AmazonBasics-Ventilated-Adjustable-Laptop-Stand/dp/B00WRDS8H0/ref=lp_3015409011_1_4/134-6088451-6951149?s=pc&ie=UTF8&qid=1566430827&sr=1-4
I've read anecdotal responses that say it doesn't make a difference really since all that matters is ventilation since fans blowing air in can't force it to take in more air than the air intake fans already allow.
So just curious.
Can't recall any specific tests I've seen, but I don't think there will be too much of a difference.
Unlike tower cases where there is (comparatively) more open space for airflow, laptop air paths are pretty restrictive.  I would not expect a cooling pad with fans to be able to push any significant amount of extra air through the internal heatsinks than the internal fans themselves.
The stand you linked is pretty inexpensive, so I'd give it a try first and see if you have thermals that are satisfactory.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
