Hi,
My 9900k is reaching temps of around 93 degrees when at load, testing with handbrake. I've just re-seated the cooler with new thermal paste and getting the same temps.
I've attached images to show the temps, and also my bios settings which is mainly defaults. I have XMP enabled to run my ram as 3000mhz.
Specs:
Ram: Corsair CMK32GX4M2D3000C16 16gb x 2 (32gb total)
Motherboard: Z390-A Pro
CPU Cooler: BE QUIET Dark Rock 4
CPU: i9-9900k
temps.JPG.8f225e3ebf3e40d9ed61331756aa35bb.JPG20190815_2008431.thumb.jpg.51db28d8527456c157762ba1773ba52f.jpg20190815_2008501.thumb.jpg.9b02f9d5452e2cf04d15c3094c053b85.jpg
i7 4790k (Hyper 212 Evo); GA-Z87X-UD3H; 16gb G Skill PC3-19200 DDR3 @ 2400MHz; GeForce GTX 1080 ; Corsair CX600M 600W PSU; Samsung 860 EVO 500GB &  3TB HDD; Windows 10 64bit.
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/
9 hours ago, cried22 said:
I would take the cooler off and reseat it. It should not be that high at all. The heat issues with the 9900k are overblown. The cooler is most likely not making complete contact with the CPU.
I did this on the day of the posting, I took it off, alcohol wiped both surfaces, put on a slightly bigger than pea sized blob of thermal and tightened it down tightly.
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12812346
A BE QUIET Dark Rock 4 200 watt cooler is not what I would use with a i9 9900k. A BE QUIET Dark Rock 4 250 watt is.
If you are using multicore enhancement a 200 watt cooler would cook a i9 9900k.
I have an issue with your motherboard choice as well.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12812572
Both of these were bought from amazon so they can get returned in change for something else if these are the issue.
This is the cooler that I have; https://www.amazon.co.uk/gp/product/B07BYP9S95/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I cant see anywhere it mentioning 200 watt or 250 watt? EDIT: nevermind, i see it in the pic
Also in short what's up with my motherboard? what do you recommend?
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12812607
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12812613
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12812638
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12812652
On 8/16/2019 at 1:02 PM, jones177 said:
I used the Ultra but the Elite would do.
Bought and installed both the elite motherboard and pro cooler and it seems the temperatures have gotten worse somehow?
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818170
How much thermal paste are you using?
People have proven too much doesn't really hurt anything but mess, but too little can be bad.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818187
I used almost the entirety of the paste you get with the BE QUIET Dark Rock 4 PRO, almost double pea sized.
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818211
4 minutes ago, Plutosaurus said:
Try hwinfo64 and report results
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818232
the temps look about right for 170w, though that's how much i use for 4.9avx, not 4.7, all 9900k should be able to run 4.7 at about 135w, you can lower the voltage quite a bit as long as it's stable, don't bother changing the cooler or mobo just yet.
I'd start with 1.2v 4.7 and if that's not stable, do 4.6. you really arent missing much. The mobo is pumping way too much to the cpu at stock.
R20 is all i have installed atm, but you can see 165w~4.9 avx around 85C, ambient is about 20C. I didn't have the best silicon lottery, so u should at least be able to run 4.7 on a lower voltage. 165w 4.7 is way too much, unless that's prime fft, or max heat.
Edit: if you are running prime FFT that's overkill
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818245
2 hours ago, Reddax said:
Something is wrong. Your minimum temps (idle?) are 60c. Unless you live in the Mojave I think your cooler installation is suspect.
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818486
Just now, Plutosaurus said:
now that u mentioned it his minimum multi is also 47x, something equivalent to MCE is on plus overkill stock voltage likely.
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818490
maybe....my idle multiplier is 50x but at idle its like 13w or something on my 8700k.
not sure why at idle so much power would be going through his cpu
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12818547
This is what I get with an i9 9900k and an Aorus Ultra with a Noctua NH-D15. The Dark Rock 4 PRO should perform the same.
Make sure multicore enhancement is turned off.
It is on by default.
https://linustechtips.com/topic/1094418-high-i9-9900k-temps/#findComment-12819145
