HELP! M. 2 Screw broke in standoff
Solved by Windows7ge,
1 minute ago, Jas99 said:By "steady enough object" will duct tape do?
If you can find a way to attach it without it potentially taking anything off the board when it comes time to remove it then yes. It'd get the job done.
2 minutes ago, Den-Fi said:it had this plastic thing that I just realized I can't describe very well.
I might know what you're talking about. Was it kind of T in shape and folded 180° with a pin on the end that snapped into place holding the SSD down?
