Fans for new build
MikeEld83
So I'm building a new pc over the next few weeks and maybe months, depends, but I've been trying to find some good and long lasting RGB 120mm fans. I will need 5 for the case that I am going to be using, the Thermaltake Versa Versa N21. I would really appreciate any ideas on which ones I should get that will give me the best cost to performance and life.
RGB fans are horribly overpriced last I checked.
Just get the black Noctua fans with an RGB strip instead.
Or buy the coolermaster H500, with it's giant 200mm RGB fans pre-installed.
are you sure about that? yeesh
Actually his current case doesn't have like any airflow that I can see anyways.
So switching to the H500 and selling the old case would help a ton for cooling.
Cheap RGB fans are like $30 which is just silly IMO, corsairs are like $70 for some reason.
https://www.newegg.com/black-thermaltake-versa-n21-atx-mid-tower/p/N82E16811133298?item=N82E16811133298&source=region&nm_mc=knc-googleadwords-pc&cm_mmc=knc-googleadwords-pc-_-pla-_-cases+(computer+cases+-+atx+form)-_-N82E16811133298&gclid=Cj0KCQjws7TqBRDgARIsAAHLHP7TOmlYb7ElvlvHe9joX5ZQ8UPS8c6cOoExIq4x9TO6TwHqVlNzmL4aAhu7EALw_wcB&gclsrc=aw.ds
The case has pretty good air flow with t fans in the front,2 in the top, and one in the back. The front of the case is a fine mess on the lower half.
I'm just going to recommend to not use the Thermaltake Versa N21. In my signiature, you can see it's the case for my second case. There are many reasons why it's not a good case. Poor airflow overall, and bad build quality. Go with something like a case from https://www.amazon.com/AeroCool-Cases-Aero-1000-Black/dp/B00VRKVTG6/ref=sr_1_8?keywords=computer+case+aerocool&qid=1565416437&s=gateway&sr=8-8. Also I'd recommend Coolermaster RGB fans. Good price and cheaper, and quiet. You can find 3 packs here: https://www.amazon.com/Cooler-Master-MFY-P4DC-153PC-R1-MasterFan-Controller/dp/B075S8RC9B/ref=pd_cp_147_2?pd_rd_w=dmHzH&pf_rd_p=ef4dc990-a9ca-4945-ae0b-f8d549198ed6&pf_rd_r=WNCBG5HRMAVNTCKMQ3W5&pd_rd_r=d3611a11-5249-4d54-899e-6d32f372771c&pd_rd_wg=kcp51&pd_rd_i=B075S8RC9B&psc=1&refRID=WNCBG5HRMAVNTCKMQ3W5
Setup No. 1: CPU: AMD Ryzen 2200g 3.95GHz GPU: EVGA GeForce GTX 780 3GB Dual FTW w/ EVGA ACX Cooler MOBO: MSI B350 Tomahawk Gaming Motherboard RAM: KingSpec DDR4 8GB Single Channel @ 2866MHz PSU: CS Series Modular CS 650M - 650 Watt Power Supply 80+ Gold Efficiency CASE: EVGA DG-73 STORAGE: 240GB Inland SSD, 320GB 7200 RPM Western Digital Hard Drive COOLER: Cooler Master ML240L - 240mm Liquid AIO MONITORS1x Dell 1920 x 1080p 24" Widescreen 60Hz, 1x Dell 1920 x 1080p 22" 60Hz KEYBOARDCheap Inland USB Keyboard MOUSE2400DPI Anker Gaming Mouse RGB CHAIR: Ikea MARKUS Office Chair
Setup No. 2: CPU: Intel i5-4950 GPU: Powercolor Red Devil RX 570 4GB VRAM MOBO: Asus B85 RAM: Ripjaws 8GB DDR3 @ 1333MHz Single Channel PSU: Insignia 450 Watt 80+ Efficiency Power Supply CASE: Thermaltake Versa N21 STORAGE: Samsung 860 EVO 240GB SSD COOLER: bequiet! Pure Rock Slim MONTIROS: 1x HP 24" 1680 x 1050p 60Hz KEYBOARD: Apple USB Keyboard MOUSE: Anywhere MX Logitech Mouse
