Recently I've stopped gaming nearly as much as I used to as I have two kids now. I spend most of my days working (i'm a software engineer), and have decided I'm going to sell my gaming computer in order to upgrade my work environment (better monitors etc).
Phase 1: Selling my gaming computer
My gaming computer is the following set up:
  • GPU: MSI RTX 2070
  • CPU: AMD Ryzen 5 2600
  • Memory: 16GB G.Skill Trident Z RGB
  • Mother Board: AORUS x470 Ultra Gaming
  • Boot Drive: Samsung 970 Evo 256GB m.2
  • Storage: 4TB 7200RPM HDD
  • Cooling: Corsair H100i V2 CPU Cooler + 2x front rgb case fans, 1x rear case fan
  • PSU: 850W
  • Case: Versa N24 Case
  • Displays: 2x - 32" Curved 1080p Monitors
  • Keyboard: Corsair Strafe RGB (Cherry MX Silents)
I'm thinking I will sell this all as a bundle for around $1,300-$1,500 (i'm open to suggestions on that price, i find it difficult to price packages like this since i've only ever built computers and never purchased them as packages)
Phase 2: Upgrading my work environment
I don't want to completely lose the ability to play games, my most played game right now is rocket league (which happens to run on macOS). I have a late 2015 macbook pro, and I believe it only supports thunderbolt 2, so finding a GPU enclosure was a bit of a struggle, but, my purchase list will look like this.
  • 2x 4k Monitor for work ($900 max, will do 1x 4k and 1x 1440p if i can't find decent enough monitors at that price point)
  • RX 590 ($200)
  • TB2 GPU Enclosure (~$200) (I've only found one that supports TB2, so would love some help on this front)
I already have a replacement keyboard for the one i would sell.
Questions
Right now my main questions are:
  1. Is this entire idea even realistic?
  2. Will an RX590 support 2x 4K displays, or 1x 4k display & 1x 1440p display. Keep in mind i wouldn't be gaming at these resolutions. I'm content to continue playing the one game that I play at 1080p, i would just need the computer to be able to run smoothly at these resolutions for normal work.
  3. Are there any good options for GPU enclosures that support Thunderbolt 2 and are no more than $300?
  4. Is there a better option for the Video card than what I'm suggesting?
  5. Is the asking price for the gaming computer fair, low or high?
  6. Is there a better all around solution to upgrade my working environment given that I have this gaming PC / monitors / keyboard to sell? I'm open to suggestions.
  7. Let me know if there are more things to consider that I haven't thought of.
https://linustechtips.com/topic/1091135-moving-to-mac-for-work-looking-for-input/
Answering your questions in order.
1: Yes and no.
2. The RX590 can certainly do 2 4K displays, it will have no issue doing so.
3. This is where the no of my answer to question 1 comes. TB2 is not natively supported for E-GPU's under macOS, and the bandwidth is so low compared to PCI-E Gen 3 16X you would bottleneck most GPU's out there. Even TB3 isn't amazing in this regard, but for 1080P gaming it is fine.
4. Your mac will be getting Catalina, which supposedly has Navi support. So if this proves to be true, the 5700 would be a better buy.
5. Honestly cannot speak to this.
6. The best alternative would be to sell your Mac as well, and buy one of the TB3 equipped Macbook Pros, due to TB2's limitations mentioned above. The only one to avoid is the 6 Core Macbook Pro 15", as it has thermal/power issues that even its replacement 8 core does not.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
Is there any way to get an eGPU working natively on a 2015 MBP?
The issue there is that selling both of these computers, the late 2015 MBP and the gaming computer described above would only net me around the amount of money I would need to purchase the same tier MBP this model year. Which seems like a miss-appropriation of funds. I could be wrong here, but i don't know if the current gen 13" mbp with the 1.4ghz cpu would cut it for me.
Again, yes and no. It might work, but will probably be rather slow and definitely be buggy due to the aforementioned bandwidth limitations.
I am actually in the same boat in that regard. But one thing you are missing in your comparison is turbo boost speeds, where new CPU's are much better. That "1.4GHz CPU" turbos up to 3.9GHz, where your 2.7GHz or 2.9GHz CPU turbos up to 3.3GHz, and with the generational improvements that will actually net to a productivity upgrade. Though one thing to note is that the model you're looking at only has 2 Thunderbolt 3 ports. As versatile as they are, you are much better off spending more for the 4 TB3 version.
Useful threads:
Total: $1891.98
OP Look here, it should give you a very in depth idea, read everything before trying 2015 macbook pro wasn't designed to be used with Egpu.
website -  https://egpu.io/setup-guide-external-graphics-card-mac/
Bandwidth limitations and proper support, TB1 and  TB2 are not solid as TB3.
Just now, MrFisc said:
I got it working, although this information seems old. The latest update refers to macOS 10.13.4
I was pointing at that for the technical information regarding TB2
Quote
If you're looking to get a MacBook, I would say that selling your 2015 Pro and going for a 13" model and getting a Thunderbolt 3 eGPU enclosure is the most viable option. You can get Thunderbolt 2 eGPUs to work, but the performance is going to be so bottlenecked and you won't be able to use it in the future since Thunderbolt 2 is no longer supported.
All the 13" models are 4C/8T now btw.
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
