Best RGB CPU coolers?
Diversityxo
I know the Dark Rock Pro 4 and Noctua are the best CPU coolers there are , but I want that extra pop on my build ..
What’s the best CPU cooler that will come close or perform as good as the DP4 and Noctua but also come with rgb?
None Most RGB fans are not great with air flow maybe this
https://www.google.com/aclk?sa=L&ai=DChcSEwiVvuba8NXjAhUS8MAKHTm-CKQYABAIGgJpbQ&sig=AOD64_21jELQS_hcw5kvFOkio2p6CVpBEg&ctype=5&q=&ved=2ahUKEwiz1tza8NXjAhVG2qwKHejtAOkQwg96BAgKEAk&adurl=
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
What cpu, ram, and case are you using?
Where are you shopping / located? Budget?
I changed my mind lol ima go with a Noctua and get the chromax accessories
