Hey,
So whilst I'm in the middle of swapping out My current case and moving to a new one and adding a couple extra parts, My knowledge is a bit rusty about what Case-Fans are good at the moment xD. I'm thinking about getting some NOCTUA Case Fans or possibly beQuiet! Case Fans whilst I'm swapping to My new SilverStone GD09B HTPC ATX Case.
My setup will be:
For the INTAKE/FRONT:
2x 120mm Fans on the Right side of Case
1x 120mm Fan of the Left side of Case
For the EXHAUST/REAR:
2x 80mm Fans
So, does anyone know of some pretty good 120mm Fans and 80mm Fans? Preferably mostly the same performance/aesthetic wise :P
I believe NOCTUA has some really good fans but I dunno cos' like I said earlier, My knowledge is a bit rusty, lol.
Thanks
Hey I'm Xiauj ^_^ Wassup :3
https://linustechtips.com/topic/1084715-case-fan-setup/
Noctua definitely makes some of the best 80mm fans on the market, due t the fact that not many people make 80mm fans.
As for 120mm fans, do you value prce to performance, or performance/noise over all other factors?
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12737821
Ok cool, good to know. I knew they were good a while back but just wanted to make sure they're good currently.
I saw some NOCTUA NF-A8 fans, are they good performance wise and pretty quiet?
I don't mind either ^ As long as its NOCTUA and that they go along nicely with the 2x 80mm fans for good performance and quietness seeing as they have both, I think. :P
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12737841
Cant say I have experience with 80mm fans in general, but here's their stats sheet
17db max is pretty quiet, but it wont move a butt-ton of air or anything.
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12738236
11 minutes ago, TVwazhere said:
-snip-
Hmm.. I could possibly go with something like, 3x Noctua NF-A12x15 120mm Fans (INTAKE) and 2x Noctua NF-A8 80mm Fans.
Hopefully that won't cause issues with the temperatures etc..
Hmm. Interesting. Will have to think on that one, for now o.O lol
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12738247
Mostly depends on how quiet you want the setup to be, and how much you wanna pay for it. Three NF-A12x25's is $90
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12738271
My thoughts exactly ;) lol. Will have to think about it. I forgot how much fans were until I looked on PCPP a few hours ago.
Last time I purchased fans was in like.. 2016? I think xD
It's a huge shame that there isn't a similar GD09B case but with space for 140mm Fans or even a 120mm exhaust or something :| Would have saved Me some money haha
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12738278
What are your specs? You might not need so many fans.
https://linustechtips.com/topic/1084715-case-fan-setup/#findComment-12747712
