Need some Feedback for my Home Network
5 minutes ago, pommedeterror007 said:Theyre both non ISP Hardware. The modem router unit is an arris motorola its wifi is just super weak so i bought the second router as my main. In the second configuration the secondary (blue) router would act as an AP like @Windows7ge states. but im not sure if it would be robust or easy to setup through a switch.
Want to know something that might blow your mind? The four ports you often find on routers are in itself a 4 port switch. It's just built in. They're not particularly intelligent devices (based primarily off ASICs if I recall). Assuming it's a non-managed switch configuring the routers software in either hardware configuration will make little to no impact on the difficulty. It'd just be a matter of which cable run would look cleaner. Wireless router to switch or wireless router to modem. Logically the network(s) would be all the same. Would make no difference.
