How can I improve 3D audio for DT 770s
Solved by Spuriae,
If you were unable to hear him at all, virtual surround likely had nothing to do with it. Virtual surround is just a position-based EQ. Raise the volume on the sounds you need to hear, lower the volume on the sounds you don't.
Featured Topics
4
1
JFRStudent ·
Posted in Photography and Videography1 -
5
6
amir2927 ·
Posted in CPUs, Motherboards, and Memory9
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
