WiFi Not Working on Elementary OS 5.0 Juno
Solved by adwilson99,
Hi All, new to this forum, but I also have the same laptop JOI BOOK 150. And I run elementaryOS, it's awesome.
I fixed the wifi as follows:
Remember the onboard wifi is only capable of 2.4G, even in windows, so don't expect lighting speed.
- Download the following driver https://github.com/lwfinger/rtl8723bu
- You'll need to compile the driver so you'll need make as well as linux headers. These commands should do the trick
sudo apt install make sudo apt install linux-headers-$(uname-r) sudo apt install gcc
- Remove the default wifi adapter.
sudo modprobe -r rtlxxxu
- unzip your rtl8723bu driver and edit the Makefile, comment out the following line, by putting a # in front of it.
EXTRA_CFLAGS += -DCONFIG_CONCURRENT_MODE
- Install the driver with the following commands:
make sudo make install sudo modprobe -v 8723bu ant_sel=2
- Your wifi should now work fine. However to make these changes permanent you need to do the following:
- Add the rtl8xxxu driver to the blacklist so it doesn't get loaded again:
sudo su echo "blacklist rtl8xxxu" >> /etc/modprobe.d/blacklist.conf exit
- Make sure that the new driver loads with the ant_sel=2 option (the JOI BOOK internal wifi adapter actually has two antennas inside, the 2nd one is much stronger, hence you get a more stable wifi signal by doing this)
sudo su echo "options 8723bu ant_sel=2" >> /etc/modprobe.d/8723bu.conf exit
- Reboot and all should be good.
Also if anyone's interested I'm starting a blog for installing elementaryOS on the JOI BOOK 150, cause it's awesome once all set up correctly,just takes a lot of work. For anyone interested you can find my notes here. https://adwilson99.wixsite.com/joi-linux
