20 minutes ago, Logan Maxwell said:
does anyone know a good case for around $0-300 that can fit 2 480m radiators and will have room for 2 custom loops.
If so please link me it.
With my knowledge there is no such thing my friend.  You want your cake and eat it to.  The top of of a case you can install 360 only nothing higher no room.  Then another 360 rad in the front.  Why you need this anyways ?  What CPU do you have what overclock do you have ?  You know liquid temps have to do with what temp your room is.  You want 74 F anything higher and the fans are gonna suck warm air into the case and your case temp will be higher thus higher temps no matter how many Rads you have.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681745
Well, I could make the budget like 400. would that get me anything? room temp is around 67f.
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681879
What? No.
As long as air being run through the radiator is cooler than the liquid in the radiator, it will continue to provide a cooling effect. Even a room at 100F/37C will cool your components adequately.
Cooler air is better than warmer air because it will more readily draw heat out of your machine, but 74F is far from being some sort of magic limit. I bet most people with an air-cooled 1080Ti would *love* to see 37C temps on their card.
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681884
5 minutes ago, LyondellBasell said:
What? No.
Yes if its intake it will bring in warm room temp with it.  A cooler room = a cooler CPU .... That is all Im saying.
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681887
in was looking at the lian li v3000, i was going to use 480mm rad intake at the bottom and 480mm rad intake at the top, use the front 3 fans and the 120 in the back as exhaust
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681888
Is that even possible ?  The bottom of the case is your PSU hmmm
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681897
51 minutes ago, Logan Maxwell said:
http://www.lian-li.com/pc-v3000/      there is a place at the bottom to mount a 480.
WOW, nice find man.  That is a sexy case.  I see where the rads go, you can even put a 360 in the front. How much is it, must cost a arm and a leg.
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681978
it's only 460 on Amazon, I'm pretty sure I could find it cheaper.
Edit: just found it for 320 on newegg :D
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12681994
Well it's a good thing I know of a few ;)
Thermaltake The Tower 900
Thermaltake Core X9
Phanteks Enthoo Primo
https://linustechtips.com/topic/1077252-i-need-cases-help/#findComment-12684897
