Best budget air cooler for i5 9400
Stevers108
Hi all!
I'm building a budget build for my friend and I was originally going to water cool his i5 9400, but he opted for air cooling. Since he's on a budget, I'm trying to figure out the best CPU cooler for a budget build! The case I'm using is a NZXT h500. I was originally going to go with a Noctua Air Cooler, but when I put in a Noctua NH-U14S in the same case during a different build, it BARELY fit. So I'm trying to avoid it due to space.
Here are the ones I was looking at:
https://www.amazon.com/dp/B00HPXZF2I/ref=psdc_11036281_t4_B07BYP9S95
https://www.amazon.com/Cooler-Master-RR-212S-20PK-R1-Contact-Silencio/dp/B07H25DYM3/ref=sxin_2_ac_d_pm?keywords=cpu+air+cooler&pd_rd_i=B07H25DYM3&pd_rd_r=85aedda0-cff5-4809-98c9-0b2586eb874d&pd_rd_w=6ZbXV&pd_rd_wg=2rfBh&pf_rd_p=64aaff2e-3b89-4fee-a107-2469ecbc5733&pf_rd_r=B3EGGVKQ9K78TFAQW9MX&qid=1561423251&s=gateway
https://www.amazon.com/Cooler-Master-RR-212E-20PK-R2-Direct-Contact/dp/B005O65JXI/ref=sr_1_3?keywords=Cooler+Master+-+Hyper+212+EVO+82.9+CFM+Sleeve+Bearing+CPU+Cooler&qid=1561423546&s=gateway&sr=8-3
Thanks guys!
Cheers
the stock cooler is enough, undervolt if not enough.
Desktop benching:
If the noise of the stock cooler is not appreciated, the Hyper 212 black edition is plenty good.
Primary PC:
You don't need more than Cryorig M9i, if that's available for you.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
