Gpu dead after a wire came loose
The long story short (r9 290x reference)
I replaced the stock cooler with my old directcu ii from a r9 280x after sanding down the parts where it needed.
I had to lenghten the wires so it can reach the card's fan terminal.
For the first try the card started,fan started,everything was working, i was like hell yeah, even temps were around 50C degree
I tried some load on the card when a cable came loose from the lenghtened fancable and something in my pc made a quiet pop and it shut down.
Pc boots and everything seems to be working exept the card.
I did fix the cables and rechecked every cable and soldering but the card doesn't turn on only the fan.
No signal and it doesn't heat up anymore.
I checked the caps and saw nothing out of ordinary
tomorrow check the card in an other pc
I would like to know what parts should i check or any advice getting it working again
Hi, do you know where the fixed wires were running when the incident happened? Look for things like small burn marks or other type of damage in those regions (it can also have affected a PCB trace for example, not only a surface-mounted component).
For future reference, if you solder cables again, I would recommend covering all exposed parts of the wires with heat shrink to make sure everything is isolated.
Sounds like you let the magic smoke out of one of the components. Unfortunately, once that is done it is difficult to get the smoke back in.
FaH BOINC HfM
Bifrost - 6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670 WiFi; Ryzen 9 7950x; EVGA 240 CLC; 4 x 32GB DDR5-5600; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; AMD FirePro W4100; MSI 4070 Ti Super Ventus 2; Corsair SF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Meshify S2; Gigabyte Aorus ax570 Master; Ryzen 9 5900x; Noctua NH-D15; 4 x 16GB DDR4-3200; 512GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750Mx
dcn02: Fractal Meshify S2; Gigabyte ax570 Pro WiFi; Ryzen 9 3950x; Noctua NH-D15; 2 x 16GB DDR4-3200; 128GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750x
dcn03: Fractal Meshify C; Gigabyte Aorus z370 Gaming 5; i9-9900k; BeQuiet! PureRock 2 Black; 2 x 8GB DDR4-2400; 128GB SATA m.2; MSI 4070 Ti Super Gaming X; MSI 4070 Ti Super Ventus 2; Corsair TX650m
dcn05: Fractal Define S; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SATA NVMe; Gigabyte Gaming RTX 4080 Super; Corsair TX750m
dcn06: Fractal Focus G Mini; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SSD; Gigabyte Gaming RTX 4080 Super; Corsair CX650m
The wire was there, the blue one l.
Wires were taped with electrical tape but it fell of from the blue one,
Now i removed from all tape so i can see the connections better
I sent pictures of the area but i cannot see any burn marks
I did not smell anything tho
The thing you said could be true but i don't want to give up so easily
Electrical tape can be unreliable, especially the cheaper kind.
It could very well be that this incident damaged parts of the PCB and not a specific component. Since those PCBs tend to be quite complex (multi-layered), I don't think it can be fixed, but maybe someone else here has an idea.
Thank you for your time
But if the PCB is broken then the fan wouldnt start either? Because it's plugged in into the PCB
A guess would be the exposed connection from the blue wire (Likely the PWM line) touched the MT214 pad underneath it. Without a schematic it would be difficult to fix and then would likely require a hot air rework station.
Your best bet is likely to donate the board to BuildZoid for spare parts.
FaH BOINC HfM
Systems:
Those MT214s look scorched. If they are, something came in contact with them that shouldn't have. I'm also kind of curious as to why you'd have open splices like that sealed with electrical tape instead of soldering and heatshrinking them.
My feeling is that this is an ex-card.
Aerocool DS are the best fans you've never tried.
I did solder and tape the wires but as it turns out the solder and the tape did not held much
A better angle and photo of those MT214,
An ex-card means its dead for good?
If it doesn't work in the other PC, I'd think it's done for, yeah.
