Need a little help with pc + console and audio
you could buy something like the sound blaster x7 to which you could put your console audio in using an optical cable then connect the computer by micro usb. you can then mix the sound so you can hear the console and pc at the same time. the only problem with that is that you cant talk on the console, Also there are probably other options than the x7 im only mentioning that one because thats what i use.
Featured Topics
Prehistoric ·
Phenz ·
sunze ·
Posted in Troubleshooting1 -
LiterallyDiego ·
Posted in Phones and Tablets0 -
ShadeBorderlands ·
Posted in Programs, Apps and Websites2 -
1
realfireguy ·
Posted in Graphics Cards8 -
AbyssSF ·
Posted in New Builds and Planning1 -
3
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
