Need help on a bluray play from hard drive
Solved by dalekphalm,
So that video is encoded in H.265 (HEVC). This is a better compression for lowering the file size of a higher resolution image (assuming ideal quality settings, etc).
However, some devices have poor H.265 decoding performance. If the file is too large, it can cause problems.
Once the transcoding is finished with the settings I specified (H.264), let's compare the file size of the new encoding vs the one you've posted.
In terms of your SmartTV, it should have no problems playing back H.264. It should also play H.265 as well, so the issue may simply be too large of a file size, rather than codec specific.
Tip: If you're going to rip Blu-Rays in the future, the recommended program is MakeMKV.
