How do I switch operating systems?
Solved by Windows7ge,
13 minutes ago, fasauceome said:Is this the menu you meant? I don't see the Linux partition, would I have to enable something for it to be recognized?
System Configuration that's what it was called but uh...I decided to check my laptop to explain this to you and as it turns out there's no Linux option there for me either...
What I did was install Windows first, then I shrunk the partition, then installed Ubuntu to the empty space. From there GRUB just took over I didn't do anything but I expected it to be there..
