So i'm upgrading a few bits in my PC and wanting to potentially change the case too as it's getting on a bit and missing some feet etc and it's huge and very heavy.
Currently I have the Fractal Design Define R4 (with window). The soundproofing is amazing and I love having a much quieter PC. Is there anything that would be similar in sound dampening but smaller and just generally newer? Not fussed about fancy rgb lighting as unfortunately my computer is hidden away on the floor not to be seen :(
Edit- also I am upgrading to a Vega 64 Nitro+, so not sure what space i'd need and how good the airflow would have to be to keep decent temps!
Thanks for any recommendations!
https://linustechtips.com/topic/1062252-good-replacement-case/
I just ordered a Meshify C it comes in tomorrow, It's pretty quiet and has insane airflow, I used one in a build for a friend a little bit ago the Define R6 is also super nice. But the Corsair 100R Silent is really quiet and budget friendly. Nothing too fancy but I've used that in the past for some audio recording PC's and it worked like a dream to keep the noise levels down.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1062252-good-replacement-case/#findComment-12551441
The newer Corsair 275Q also comes to mind as a possible choice.  PWM fans and a repeater are included if you need them for the case, and it has sound damping on front, both side panels, and top panel.  It's also priced very competitively as well.  Let me know if you have any questions about the case, or looking for additional features.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
https://linustechtips.com/topic/1062252-good-replacement-case/#findComment-12551505
Fractal Design Define C. Basically the same height and depth, but about 4" shorter. Comes in a solid side panel, acrylic window and tempered glass, as well as the Meshify Version which isnt silenced/airflow balance like the Define C or your R4 are.
https://www.fractal-design.com/home/product/cases/define-series/define-c
https://linustechtips.com/topic/1062252-good-replacement-case/#findComment-12552682
Good suggestions on the Define C, but with the R4 you can also add more fans.  I did with my R6, airflow is better and still quiet.  May be an option instead of buying a new case that's arguably very similar.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1062252-good-replacement-case/#findComment-12552742
