Quad-SLI XP Retro-Build - Help needed
Ph1lo
Hi all,
I'm new to the forums, and new to this whole endeavour so please be gentle with me... I'm trying to relive my youth, albeit with a budget that I couldn't afford now if these parts were all current and new, and build a gaming machine the likes of which I could only have imagined back in the day...
The Plan
Over the last month or so I've started to accumulate parts to make what I hope would become the most ridiculous/brilliant but functional Windows XP based gaming machine. I did a fair bit of reading and decided that I wanted to base my build around a Quad-SLI setup using GTX 780 TI's. I understand that these were the last cards to have official driver support within XP, supported Quad-SLI and were relatively affordable and easy to come by. I also understand that SLI is poorly supported and rarely offers any advantages, certainly beyond 2-way in most cases. None the less the whole point was to go over the top just because I can.
The next issue I had was finding a Quad-SLI supporting motherboard with XP driver support. A brief dalliance with an Asus Rampage III Extreme (misunderstanding that despite the four PCIx16 slots, it only supported Triple-SLI), and I found an excellent deal on the newer equivalent.
The Build
I've constructed my machine comprised of the following parts, and thanks to the truly superb "Snappy Driver Installer" I'm pleased to say that Device Manager shows that all hardware is installed and working as it should, despite Asus not offering official XP support on this board...
Asus Rampage IV Black Edition X79 Motherboard
Intel i7-4960X CPU
Be Quiet! Dark Rock 4 Cooler + Silent Wings 3 Fan
4 x 2GB Corsair Dominator Platinum 1600Mhz DDR3 (Obviously only <4GB is recognised by XP, but at least it's setup as Quad channel)
2TB Firecuda SSHD
EVGA 1600W Platinum PSU
6 x Corsair LL120 Fans (3 front intake, 2 top exhaust, 1 rear exhaust)
2 x Corsair AF140 Fans (bottom intake)[/list][/list]
So far I've installed just two 780 TI's to get it running, including using the Asus ROG Flexible SLI Bridge that came with the motherboard and was still sealed in it's packaging. I have a 3rd card ready, and am still on the hunt for the 4th at the right price. All are matching MSI GamingX 3GB models.
The whole machine is housed within a Corsair Carbide Air 740 High Air-Flow Case, which to my mind looks awesome, if not at all period correct.
Windows XP (32-bit) is installed successfully using IDE mode on the SATA Controller and Easy2Boot to do the installation itself. I was pleasantly surprised to find that it was still able to connect to Windows Update services too, so after a busy few hours of downloading the installation is also fully patched as far as it will go.
In terms of other software, I've only installed MSI Afterburner (no changes to settings as yet, just useful for monitoring) and "WinCDEmu" to mount ISO's when needed.
The PC is working nicely, boots relatively fast and seems to run smoothly. I've had no issues at all, no crashes, although only briefly ran one game for 5 minutes as a test.
The Problem
I have just one issue that I'm hoping more seasoned professionals can help me with, but I fear that it's a big one.
I have successfully installed the NVidia drivers for this card/OS combination (368.81), and it appears to have installed correctly. Both cards are seen in Device Manager, MSI Afterburner and the NVidia Control Panel.
However, that same control panel does not show me the option to enable SLI. It's missing completely - no mention of SLI anywhere at all.
This is my first SLI build so I have no prior experience, but it's clear from what I can find easily online that there should be a menu option to enable/disable SLI which should just automatically show up at this stage, but it just doesn't.
All PCI Slots are enabled, set to "Gen3" in the BIOS. The GPU's are installed in slots 1 & 4 as directed by the manual for 2-way SLI. Both slots are operating in x16 mode as far as I can tell.
My thoughts as to possible causes, none of which are particularly good:
Could using the 32-bit version of XP be a problem?
Despite the successful installation of all drivers, is XP just incompatible with X79?
Is something missing that device manager can't see at all, that is required for SLI to work?
Could be a BIOS setting that I've not seen that could affect SLI?
Seems unlikely but I guess my SLI Bridge could be faulty...
Can any of you wonderful people offer any suggestions as to what the problem might be?
In the absence of any other ideas my backup plan is to temporarily swap out the HDD with another and do a quick Windows 10 setup to see if SLI will detect properly then with newer drivers, which would at least eliminate any hardware issues...
The Solution?
I look forward to hearing from your collective wisdom, and thanks in advance for any help you can offer :)
Simple, use Windows XP Professional SP3 which is 64bit.
Personal Desktop":
Luna, the temporary Desktop:
So is that it - 32bit doesn't support SLI? That'll be great if that's all it is :)
There isn't SP3 version of the XP 64bit as far as I know, unless there is some unofficial one.
Intel Core i9-10900X, Asus TUF X299 Mark 1, 64GB DDR4 3200MHz, Asus GTX 1080 Strix, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, DC Assassin III, Meshify 2
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 24GB DDR3 1600MHz, Asus GTX 1080 Strix, 500GB, 250GB & 120GB SSD, 2x 4TB & 2x 2TB HDD, Fractal Define R5
PC 2: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
PC 3: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 16GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Yea using xp alone is a pretty big hindrance to the system let alone trying to use 32bit. You'll basically have the slowest gtx 780 sli setup possible with only dx9 available
Thanks, and I agree XP is potentially a hinderence to the hardware, but the other way of looking at it is that it should be the best XP can be... The whole point is to be retro. I'll probably end up having multiple boot environments anyway, but wanted to start with XP. DX9 and below is fine, as I'm looking to only use this machine for DX9 or older games.
i dont think what i was saying was getting across.
A single 780 is going to play dx9 games just as well as 3 of them. there aren't really any dx9 games that will take advantage of 3 gpu's even from a resolution point as 3 gpu's will not combine their vram. The 780 far exceeds what the games are expecting already. the second might help but the 3rd will be doing almost nothing at all.
If you want to run windows xp games (even in dx9 mode) I would suggest using windows 7 instead as it supports almost any program from xp without issue , even regular oldschool disk games. Otherwise , you'd essentially just be using xp to purposely make the system slower with absolutely no advantages over 7 , not even the UI as 7 can use the same older UI as well.
XP 64 bit only went up to SP2, since it's based on Windows Server 2003 64-bit. SP3 only exists for the 32-bit version. Support periods were identical, though.
I doubt DX9 games can properly utilize even a single GTX780Ti. The 4960X also isn't the best CPU in terms of raw IPC one could use for this.
I'd say the XP era ended around 2009, so I'd wager the best sensible XP gaming rig would be an i7-9xx for s1366 with triple channel DDR3 and SLI GTX280s.
or go Quad 8800GTX or something, lol.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
If you want to run windows xp games (even in dx9 mode) I would suggest using windows 7 instead as it supports almost any program from xp without issue , even regular oldschool disk games. Otherwise , you'd essentially just be using xp to purposely make the system slower with absolutely no advantages over xp , not even the UI as 7 can use the same older UI as well.
Aha ok thanks..., that's useful advice. Part of the reason for wanting SLI is to cater for my Ultrawide display which I believe the extra cards will help with. Going to Win7 is certainly an option though, especially if it makes it work!
I was originally going for an X58 build, but finding a Quad-SLI supporting board has proved to be essentially impossible so far.
stick with 7.
during windows xp's time when people tried running 3 gtx 8800's or 4 2900xts in crossfire x the systems were INCREDIBLY inefficient. The first two cards were loaded somewhat with the 3rd and 4th barely being used due to just poor software and hardware and lack of support.
it was ironed out by the time the 780 and 7 rolled around so just use 7.
Just now, emosun said:
stick with 7.
Thanks - really appreciate the advice.. I have it somewhere so will give that a go.
thats becuase quad sli wasn't a thing
Technically not true. EVGA released a Quad-SLI X58 Classified board, but as far as I can tell that was the only one!
and thats well into the windows 7 era not xp
Yep understood.
