Python Variable Subtracting and If/Else statements
Go to solution Solved by reniat,
instead of = < do <= for less than or equal to
Also, make sure to indent the lines in the if and else statement since python uses indentation to structure logic:
if current_year - int(patron_year) <= alchohol_consumtion_age:
	print("Tsk, Tsk, no alcohol for you")
else:
	print("It's Beer O'Clock, my dude or dudette")
I'm new to python, so I wanted to do a easy project to get some practice. I decided on a calculator that determines if you're of the age to drink alcohol. I'm in the US, so it's 21. I have the user input part working, but when it comes to the calculating part, I'm having some trouble. If anyone knows how to help or has some good resources, I'd be very appreciative. Here's my code:
current_year = 2019
alchohol_consumtion_age = 21
print("--------------------------------------")
print("~~~~~~DRINKING AGE CALCULATOR~~~~~~~")
patron_year = input("What Year Were You Born In, My Friend? ")
print("Ok, so you were born in " + patron_year)
patron_day = input('And what day might you have joined us on earth? ')
print("Ahhhh, the " + patron_day)
print("I had a cousin, who was born on the very same day! What a small world it is")
print("what a small world, indeed")
if current_year - int(patron_year) = < alchohol_consumtion_age:
else:
print("Drink Responsibly")
print("-------------------------------------")
Also, whenever I run it, I get this error:
Quote
 File "/home/brett/python test.py", line 12
SyntaxError: invalid syntax
Terminated
Thanks
(also if i left out any info im sorry, i didn't know what to and what not to post)
else:
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
