I'm gathering the parts for my first water cooling loop and I've pretty much figured out everything else apart from tubing
solid tubing would be much better from a visual standpoint but since I'm not really comfortable with bending yet I would pretty much rely on fittings for the bends(would that even be an option?)
plus the less clouding compared to flexible tubing wouldn't hurt
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1055231-solid-vs-flexible-tubing/
I'm confused, are you asking a question if you can flex solid tubes? If you used solid tubing your tube runs would be dead straight otherwise you risk leaks at the fitting.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
Just now, knightslugger said:
I'm confused, are you asking a question? If you used solid tubing your tube runs would be dead straight.
my question is, is it possible to use solid tubing without making any bends?
Custom water cooling  .. Do not do it its expensive and a pain in the ass.  Just get an AIO..
That being said if your going to water cool and you want to see the fluid running through the tubes Glass or PETG is the way to go.  They make bending kits that help also heat guns are cheap.  Just get more tube then you think you will need  and then get extra to practice its not super difficult but you will make mistakes.  Soft tubing you need less fitting thus the cost being less so if your trying to custom cool on a budget soft is the way to go. PETG is more expensive because you will need more fitting and Glass is even more expensive because you cant rely bend it.
yes. you use angled fittings and configure them so that they are on the same plain as the opposing fitting.
System specs:
Absolutely. Glass tubes for example cant be bent (easily) so you have to use fittings
Image result for glass tube watercooling
is there any difference between petg and glass tubing?
great, this is exactly what I'm trying to replicate
PETG is VERY hard (and brittle) plastic, glass is... well it's glass.
System specs:
Also before you even think about custom cooling you need  to PLAN , PLAN , PLAN  becouse if you dont you will have issues.
that's why I haven't ordered anything yet
I'm just trying to create a basic sketch on where everything will go
I mean does petg cloud over time or something like that?
PETG can be bent and is easyer to work with and is cheaper but Glass stays clear and looks allot cleaner but is also more expensive.
I'll try with glass then just for the better looks
yes it can cloud over time. And it's a huge pain in the ass to clean. almost easier to just recut new PETG. but that gets pricy.
i am an advocate for soft tubing for new Custom liquid cooled loopers. yes it clouds, but you can pick this stuff up at the hardware store for a pittance, requires less fittings, and is less complicated. It also helps build confidence.
System specs:
I think I might be overextending a bit for my skill level but I will try with glass and see what comes out
I honestly wish I would of just used hardline tubing from the start, soft tubing clouds us and it honestly irritates me. One thing of note, use the largest diameter of tubing if you're using dye in your coolant, the thin stuff i have the colour looks a lot lighter than my reservoir again, this bugs me. 42421705_10155760032671847_6726172107002085376_o.jpg.ccf94f49863dffcdc56bdb793a36016f.jpg
Do you have a plan on how to cut the glass to length?
System specs:
you can get tools for cutting glass, some are better than others, Glass is the best material tbh for clarity. You can buy 90 degree bent glass. I've just skimmed the thread but you said PETG is hard and brittle, that is incorrect, PETG is softer than Acrylic, you can hit PETG with a hammer and it won't shatter, acrylic will. People used to say PETG was better as it could flex further than acrylic, this forced B Neg to make a video on the subject showing him bending Acrylic tubing to debunk the fragility of the material.
It really isn't that difficult to do at all. Bending PETG is easier than Acrylic and you can buy glass pre-bent, Mayhems offered a service to bend glass for you, you could send you petg or acrylic tubes and they would mimic them in glass.
I've planned and planned, it never, and i mean ever goes to plan, you will always need to adapt.
Stuff at hardware stores is lined with plasticiser so please don't recommend this to new watercoolers. It will gum up their loops and they won't understand why, then probably blame it on the coolant used.
There.... some wrongs corrected.
@Benjeh I never said it was difficult I said buy extra because you will make mistakes. Also also if you dont plan you will make mistakes and thats not something you want to make when working with thousands of dollars worth of components.  Also the more you plan the less you will have to re-buy items or spend money on shipping for piddly crap.
Acrylic is what i was thinking of. i brought up cutting glass in case the OP hadn't quite thought that far ahead (OP is a new looper).
so is "water cooling soft tube". Plasticiser is what makes it flexible. The point i was making, and will continue to advocate for, is that flex tube is CHEAP AS HELL when it needs to be replaced or if you make a mistake and very easy to work with.
System specs:
Please read what I wrote again please.
You said, plan plan and plan again because if you don't you'll have issues, this sounds like you won't have issues, which is false.
That is what you said,
Thats what I said, Can you show me where I said "don't bother planning"?
Incorrect, List of plastizier free tubing I have used.
  1. Primochill LRT
  2. Mayhems Ultra clear
  3. Tygon e1000
Apparently alot more manufacturers are now producing tubing that doesn't contain plastizier, so sorry.... you're wrong.
