Posted June 11, 2019 Author 14 hours ago, WoodenMarker said: For 120mm fans, it doesn't really get any better than NF-A12x25's if you have money to blow: https://item.jd.com/7775710.html If you want to save a bit of money, SW3 High-Speed's are also excellent: https://item.jd.com/100000157342.html You can see some comparisons of the fans in the Highly Restrictive PC Case Simulation section: https://www.thelab.gr/reviews/heatsinks-coolers-watercooling-reviews/noctua-nf-a12x25-and-noctua-nf-p12-redux-series-fans-review-r701/ How good are they compared to the BeQuiet Silent wings 3 and Corsair ML120 and Cooler Master MasterFan Pro 120 Air Flow? The noctura seems a lot more expensive. Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB CPU: Ryzen 9 5900X Case: Antec P8 PSU: Corsair RM850x Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2019 You've created a pointless loop of air. It goes in the front the immediately out the top. The ram does't really need active cooling. Mechanical Keyboard Switch Lubing Guide Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2019 Author 1 hour ago, geo3 said: You've created a pointless loop of air. It goes in the front the immediately out the top. The ram does't really need active cooling. Well it does feed fresh air into the radiator though, what do you suggest? Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB CPU: Ryzen 9 5900X Case: Antec P8 PSU: Corsair RM850x Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2019 1 minute ago, williamcll said: Well it does feed fresh air into the radiator though, what do you suggest? Flip the rad and the rear fan. Mechanical Keyboard Switch Lubing Guide Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2019 Author 41 minutes ago, geo3 said: Flip the rad and the rear fan. there's only one 120x120 space for the rear case fan. Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB CPU: Ryzen 9 5900X Case: Antec P8 PSU: Corsair RM850x Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2019 Just now, williamcll said: there's only one 120x120 space for the rear case fan. Why do you need more than one space to flip it? It takes the same space no matter what direction it blows. Mechanical Keyboard Switch Lubing Guide Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 11, 2019 9 hours ago, williamcll said: How good are they compared to the BeQuiet Silent wings 3 and Corsair ML120 and Cooler Master MasterFan Pro 120 Air Flow? The noctura seems a lot more expensive. You can see some comparisons here: When it comes to being the best, the NF-A12x25 is it. Yes, it's expensive but there are cheaper options if you want to spend less. I mentioned the SW3 HS' but the NF-P12's are ever so slightly cheaper if really want to drive the cost down. https://item.jd.com/7988725.html MasterFan Pros aren't nearly as good as any of the other fan suggestsions and ML120's aren't as quiet. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 18, 2019 Author Well with this build both CPU and GPU resides at 72C on full load: Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB CPU: Ryzen 9 5900X Case: Antec P8 PSU: Corsair RM850x Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 31, 2019 Author Here's an end of year update, trying to figure out a better solution of the two: This version is decent and keeps my CPU around 80C, but suffers from negative air pressure where the dust filter is drawing air in. This version has a lot more air pressure where I could feel air coming out of the PCIe covers but could go up to 84C at times. Any suggestions? Would vertical mounting my GPU helps with CPU temperature? Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB CPU: Ryzen 9 5900X Case: Antec P8 PSU: Corsair RM850x Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 9, 2020 On 12/31/2019 at 12:45 AM, williamcll said: Any suggestions? Would vertical mounting my GPU helps with CPU temperature? Probably not. Positive pressure is only good for reducing dust accumulation but is generally worse than balanced or negative pressure for cooling. Take your pick. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
