i want to play some modded minecraft, but it seems like i get HUGE lag spikes while i play. They either come randomly or if i drop/something else happens. I got a screenshot of the lags spikes. i cant play at ALL. And i also noticed that the debug pie gets invaded by the "tick" thingy. Dont know what that means tho.
https://linustechtips.com/topic/1054045-minecraft-modded-lag-spikes/
Are you the one hosting or is somebody else?
I'd recommend that you try disabling other unnecessary tasks, giving Minecraft a higher priority than other problems, and checking if your RAM or HDD usage maxes out when you get the spikes.
Quote
Lag spikes are caused by three possible things:
Just remember, there are multiple ways to fix these problems, and multiple things that may be causing these problems.
  • Too many packets!
    Minecraft can only handle ever-so-many chunk updates in a single setting; tick. Because it cannot finish all the updates in that single 1/20 of a second, it freezes the world until it is able to complete the processing for that tick.
You can improve the amount of work it can do by getting a better CPU; processor (or giving Minecraft more priority over other tasks). RAM only allows you to have a greater workload; not go through that workload quicker.
Because the server and the client (if you're playing single-player) are both linked, your game freezes when it is unable to finish all the work (updating of data; the world OR rendering the world*) within the time frame of a tick (1/20 of a second).
* Note: More than 20FPS means more than one frame created in a single tick.
  • Wait. I'm still writing...
    When you have a Minecraft world, the game constantly saves the world to the disk (unless you've increase the interval that it does this) every 3 seconds. However, if the server is unable to write to the disk, it freezes the server to ensure that the data state that needs to be saved does not get changed. If it can save it in one go, of course - Everything will continue as per normal.
Pretty much, the only way to prevent this is to stop all, or at least the processes/tasks/programs hogging I/O capabilities in background that is reading to the disk, or get a better hard disk drive.
(i.e. Steam updating files, copy-pasting commands, saving school/home/work-work etc.; anything involving reading and writing to a disk)
  • Inefficient coding, AKA. Bugs
    Very unlikely, if not - Not even applicable here, but there may be bad coding in the game and mods' codes that make it leak memory or constantly remember new things in memory without clearing out redundant values.
Though some of the large mods are known to do this, and most of them by now have already fixed most (if not, all) problems causing spikes in memory usage. The only way is to solve this is to fix the coding yourself, if the source code is released.
Source: Stack Exchange
7
7
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
Its an server but im not the one hosting it. And as you can see in the minecraft screenshots minecraft doesnt use all the ram i allocated to it. so i dont think its the ram. And i got an 1tb SSD, it got good read and write speed but imma check first if it goes up to 100%
modded minecraft is far from a polished experience and it can bring even the best systems to there knees also on maps like that the water physics can cause Issues.  Did you down load the using the twitch launcher? and if so did you turn the ram usage to max?
I use the Twitch launcher yes. and no i didnt turn the ram usage to the max since it barley uses 50% of the ram while having 6gb allocated. And this might help yall understand why im so lost with all this fps drops. I aint playing on some normal world... Its an skyblock.. with literlly NOTHING near me except my island. so im super lost why i would have so bad fps. image.thumb.png.b4fc5eb142c8e5ef72c23f369fcd820c.png
Is this a custom modpack, or a pre-configured one (a FTB pack for example)?
Also, the server could be responsible for the lag; the sever might be having RAM, CPU, or network issues that increases latency and causes these lag spikes for clients.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
I play skyblock and project Ozone and Fool craft and all of them say to turn up the ram usage in the twitch launcher.  Skyblocks can cause issues with textures especially water and lava try picking them up with a bucket and seeing if that helps. Also make sure there is no water flowing from your island down because that can cause issues as well. along with vines
Its an FTB modpack. And im the only one on the server that is experiencing lag spikes. there are currently around 4 other people playing.
