Hi Everyone,
I'm hoping to look for some good recommendations/help on purchasing the best IEMs I can get for $150 USD or less. I need it to work with my OnePlus 3 Android phone however. My current IEMs are the Beyerdynamic ie 200. They do not work well with plane flights' infotanment system and are no good with my phone. They're good with a decent power source like my computer or work laptop.
Alternatively, I would be open to the idea of closed back noise isolation or noise canceling over-ear headphones for about $200 USD or less as well. I'm just trying to look for the best thing I can use for my phone while waiting at the airport and on the plane with the infotanment system. I will be traveling but my current earbuds are no good.
Help is very much appreciated.
Thanks in advance!! I'll be looking for some myself in the meantime.
EDIT: I do not need to make phone calls and volume adjustments are optional to me.
https://linustechtips.com/topic/1046985-help-best-iems-for-under-150-usd/
Depends on the sound signature you're looking for, but I'd say look at Shure SE215/315, Massdrop X Nuforce EDC3
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
Check audiobudget.com and their Leaderboard.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I would definitely need active noise canceling first priority and hopefully it works with both the plane and the phone.
Then I'd consider being able to listen to whatever quality next because the current earphones I'm using can't do the first thing well.
I will do that thank you :)
I see, active noise cancelling was not mentioned for the IEMs so... Not to mention that depending on the type of eartip you might not need it :)
If you want noise isolation, look into getting aftermarket ear tips from Comply. I have their isolation tips on my Klipsch R6 and it's incredible how little outside sound gets through, not to mention how much more comfortable they are. I noticed there's quite a bit more bass after changing from the included silicon tips (they were definitely lacking before and now they sound a little more bass heavy than I'd prefer) so keep in mind they may change the sound of your IEMs, but I'm very impressed with the isolation they provide.
Ah crap. ANC would be nice! Sound isolation is minimum!
I think the 3 cone tip would be preferred if possible. I have a 3 cone tip and some foam earbuds that i could try on the IEMs if those fit
