Hello all,
I want to preface this with the fact that I do not know everything and this is just something that happened to work for me.
I upgraded from a GTX 1060 to an RTX 2070 EVGA XC Gaming https://www.amazon.com/gp/product/B07J63W42X/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
I had terrible coil whine.. It's overclocked +80 on the core and +500 on the memory but that made no difference. I could hear it over fans turned all the way up.. I looked at buying a new PSU which I didn't want to do because this https://www.amazon.com/gp/product/B079HGN5QS/ref=oh_aui_search_asin_title?ie=UTF8&psc=1 is only a month old in my system. I looked at UPS systems but i read that that might not even work so i figured I'm just screwed.
I happened to buy a new Motherboard. Going from this https://www.amazon.com/Prime-Z390-P-LGA1151-Intel-Motherboard/dp/B07HCT5GBD/ref=sr_1_fkmrnull_1?keywords=asus+prime+z390p&qid=1553182368&s=gateway&sr=8-1-fkmrnull to this https://www.amazon.com/gp/product/B07HCXT591/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
That (mostly) fixed the coil whine!!!!! It's still there but i have to turn everything down and put the game on mute to hear it.
This post is not a how to guide on how to fix coil whine but hopefully someone can see this and see that there is another potential cause/fix for coil whine.
Hopefully people who know more than i do can chime in here. Thanks
https://linustechtips.com/topic/1046766-reduce-coil-whine/
EVGA  is the worst brand out there!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1046766-reduce-coil-whine/#findComment-12413501
Stupid statement. "EVGA is the worst brand out there!!". In what, exactly, and why? You can't just make such a statement and give no arguments.
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/1046766-reduce-coil-whine/#findComment-12413591
My limited experience with EVGA tells me that this statement is false. The only EVGA product I've seen in person that is faulty/doesn't work/is broken was a used 970 SC that my friend got off ebay (seller did not list it as broken); long story short, the GPU had borked VRMs that coil whined with a primal screech before the GPU stopped giving video output. Something was def wrong because the back of the PCB was roughly 60C to the touch, I damn near burned my fingers taking it out of the system. Neither me or my friend know how that card broke, but it was either the seller or a previous owner at some point; GPUs don't ship like that, they either work or they don't.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1046766-reduce-coil-whine/#findComment-12413617
All GPUs are different and some may have more coil whine than others. I'm not trying to go into who has more issues than who. I just want to start a discussion about Motherboard affecting coil whine. In my research i found no link between motherboard and GPU coil whine but mine went away with a different motherboard. I want to figure out why and maybe someone will find this helpful.
https://linustechtips.com/topic/1046766-reduce-coil-whine/#findComment-12413893
lol...
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/1046766-reduce-coil-whine/#findComment-12413954
