Hi everyone! I'm currently in a bit of a mess. I'm nearing the end of my build and I'm only missing the power supply and I'm looking for recommendations as I don't want anything to go wrong as this is my first build. I've heard 550w with 80+ bronze will be ok, but I'm not sure.
Specs:
Case: Corsair 275R
CPU: Ryzen 7 2700X
GPU: MSI 1080ti
Fans: 6 X 120mm
Cooler: default Ryzen one
HDD: 2TB Western Digital
SSD: 250GB western digital
https://linustechtips.com/topic/1046147-power-supply/
What's your budget?
I usually recommend 80+ Gold if you can get it. 550W should be enough, but I would probably go with 650W if it were me.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1046147-power-supply/#findComment-12407576
2 minutes ago, KieronGamesX105 said:
I'm buying through amazon uk
Not through Amazon, but the Formula 550W is a good one. Quiet, multi rail, and performs well.
https://uk.pcpartpicker.com/product/zBfmP6/bitfenix-formula-gold-550w-80-gold-certified-atx-power-supply-bp-fm550ulag-7r
If you don't care about noise too much, and it has to be through Amazon, there's the TX550M on Amazon.
https://uk.pcpartpicker.com/product/dDH48d/corsair-txm-gold-550w-80-gold-certified-semi-modular-atx-power-supply-cp-9020133-na
https://linustechtips.com/topic/1046147-power-supply/#findComment-12407607
I know it's not either of those and I'm sorry to be a pain. But would you say this would be enough or should I just go for the TX like you recommend?
Corsair CP-9020121-UK CX Series 550 W CX550 ATX/EPS 80 PLUS Bronze Power Supply Unit - Black https://www.amazon.co.uk/dp/B06X9BV5PR/ref=cm_sw_r_cp_apa_i_9-sKCb5VRBHM4
https://linustechtips.com/topic/1046147-power-supply/#findComment-12407639
Dude, you're getting a £600 GPU and a £250 CPU, yet you want to save £10 on the PSU?
The Formula is a better PSU.
It has one fewer cable, but it has 6 SATA connectors instead of 5 on the CX. It has 2 Molex connectors instead of 4 on the CX.
It's quieter at all loads than the CX.
It has a within spec hold up time of 17ms Vs 12ms on the CX. Though the CX you can buy today will probably have an even shorter hold up time.
And it has multi rail.
https://linustechtips.com/topic/1046147-power-supply/#findComment-12407897
